Fluent Heat release rate contour – non premixed combustion
    • pester98
      I have performed a simple, RANS simulation, air methane non-premixed combustion (steady diffusion flamelet). I would like to visualize the average heat release rate, q, contour from the combustion process in my domain. Is there a way to visualize it? Or a UDF? If so how would I be able to obtain a contour?
      Thank you for your help.
    • Swathi V. V.
      Hi Which version of fluent are you using?
      From v19, heat release rate is readily available for post processing in non-premixed combustion model. You can find it under PDF option in contour as shown below.
