August 5, 2019 at 2:50 pm
Muchanical
SubscriberHello Everyone,
I have an easy question and would be happy if someone can help me.
I simulated a transient simulation with Fluent ending after 1 second with 100 timesteps. I saved the results named "ts-001.cdat", "ts-002.cdat", and so on. After the simulation, I closed the saved case-file. Now I want to continue this simulation from 1s to maybe 2s. If I open the transient case-file once again and initialize with the last timestep-number 100, it starts with a current time of 0s.
So, how to change the starting current time to maybe 1s and how to write the result-files starting with "ts-101.cdat" and not with "ts-001.cdat"?
This should make it as if I had the simulation run from 0s to 2s from the beginning. I want to avoid time-consuming renaming with a lot of another software.
In the end, I want to attach the animation of the new simulation to the animation of the preceding simulation. I create the transient animation with CFD-Post
Best regards,
Mustafa
PS
ts stands for timestep -
August 5, 2019 at 3:28 pm
Ansys EmployeeYou need to read in the data and then continue running. However, .cdat isn't a Fluent file, it's a cut down dataset for post-processing. You need a .dat file.
August 7, 2019 at 5:22 pm
Muchanical
SubscriberHello rwoolhou,
thx for the reply.
So, there is no possibility to change manually the starting timestep in Fluent? That would also be helpful in other situations...
I didn't save the last result as *.dat-file. For the next time I will do it, thank you.
Now my problem is, I saved only the *.cdat-files and the *.case-file. I have already searched for it but how can I export a *.cdat-file in CFD-Post to a .dat-file to read this with Fluent and continue the simulation as you said because I do not have any *.dat-file.
I have tried to rename the ".cdat" to a ".dat" manually with typing in. One time it worked but another time there were many issues caused by data damaging. Would you prefer such a manual renaming even if Fluent is opening the renamed *.dat-file correctly?
Best regards,
Mustafa -
August 8, 2019 at 4:55 am
DrAmine
Ansys EmployeeYou can set that via rampant variable. -
August 9, 2019 at 9:48 am
Ansys Employee.cdat is a cut down data set which is ONLY used in CFD Post: it can't be read back into Fluent. The data file contains the current time step and flow time: so reading this in will allow you to restart from where you left off.
If you really want to just change the time in a model (usually for post processing) then read this https://www.eureka.im/4995.html Use at your own risk, and I won't elaborate on their comments as this is a public forum. I use the commands irregularly as needed.
August 12, 2019 at 10:45 am
Muchanical
SubscriberThx @rwoolhou and @abenhadj. My first question is answered, so this discussion is solved.
The commands (rpsetvar 'flow-time ##) and (rpsetvar 'time-step ##) are working where ## is the required value.
@rwoolhou: Can you clarify why it is risky to use this, pls? Would it make a numerical difference to the results if I change the starting time with the above commands during starting a new simulation?
Thx for the help.
Best regards,
Mustafa -
August 12, 2019 at 12:08 pm
Ansys EmployeeAny time you use an rpsetvar command you're changing something in the simulation. The above are fairly safe, but could mess with the case-data links: if you mistype something you could also change something important.
2524
2066
1279
1096
459
