March 7, 2022 at 1:17 pm
mxmgr
SubscriberHi,
I'm looking for a solution to specify an unit parameter, when I'm working with Fluent from batch in a journal file .
First, I define the parameters process:
def par ip adv ui us "ux" 5.5
def para enable yes
Here, we've got an input parameter "ux", which describes a velocity. Thus, we can see in "Parameters & Customization" --> "Parameters" --> "Input Parameters", the parameter "ux" which takes value (5.5).
It's important to observe that no unit is specified in this parameter, which is a problem for the next command. When I want to apply this parameter in a boundary condition, with these commands :
def bc zt label-1 velocity-inlet
def velocity-inlet label-1 "ux"
thus, we've got these lines on Fluent's console :
Velocity Specification Method: Magnitude and Direction [no] yes
Reference Frame: Absolute [yes] yes
Use Input Parameter for Velocity Magnitude? [no] yes
Name of parameter ["parameter-2"] "ux"
ux value (in [m/s]) [0] 5.5
and this error appears :
Error: 'ux'is predefined expression. Please change name.
Error Object: #f
Fluent commands doesn't recognize the implemented parameters.
Do you have suggestion to fix this issue ?
Best regards,
mxmgr
March 8, 2022 at 2:16 pmRob
Ansys EmployeeIt's easier to define the parameter with the units, so "parameter-2" is 10 [m/s]
I'd also avoid using two letter labels as some are already taken by Fluent for field variables: pick a more distinctive label ie "inlet_param"
For the TUI commands it's also advisable to write them in long hand for journals as it's easier to then review what was written, and use the full syntax.
/define/boundary-condition/zone-type label-1 velocity-inlet
2524
2066
1279
1096
457
