September 2, 2018 at 3:29 pm
danielc358
SubscriberHi good afternoon!!!
I have two doubts, one of them is how I put interpolation values in the Inlet and outlet in Fluent, and the other doubt is if it is necessary to put other characteristics besides the density for solid materials in the Fluent and if it is necessary to put the other characteristics of the material, How do I do this?
Daniel
September 2, 2018 at 5:19 pm
raul.raghav
SubscriberIf you want to interpolate the results of one case to another, you can use File --> Interpolate. See attached youtube video to see how it is done:
Transfer Data from One Fluent Case to Another Using Interpolation Files
If you want to import the information at the boundary of one case to another, you can use File --> Write --> Profile and File --> Read --> Profile. See attached youtube video to see how that is done.
Use Profile Files to Transfer Boundary Data
If you're dealing with just a fluid flow simulation, you just need a solid material defined and the properties of the defined solid doesn't matter. If you're dealing with heat transfer or FSI studies, relevant properties of the solid needs to defined. You can edit the material properties under Setup --> Materials --> Solid --> Create/Edit.
September 2, 2018 at 8:13 pm
danielc358
SubscriberHi good afternoon!!!!
How do I convert the excel file to * .ip?
Daniel
September 3, 2018 at 5:30 am
DrAmine
Ansys EmployeeYou need to take care about the interpolation file format and how it is constructed so that you can translate an Excel file to *.ip. Sometimes it is a better idea to start from the Interpolation file written out by Fluent for the particular case one wants to adjust.
However I can tell you that it would be difficult.
Why do you want to convert an Excel file to IP file? Do have experimental data for the whole domain (at every single point)?
September 4, 2018 at 4:34 pm
danielc358
SubscriberI was needing to load expremental data in the inlet and the outlet, but I'm having trouble creating the * .ip interpolation file, is there any tutorial that teaches you to do the interpolation with the creation of the * .ip file in the inlet and outlet?
Daniel
September 4, 2018 at 4:39 pm
DrAmine
Ansys EmployeeAs far as I know, there is not such a tutorial to do that for the *.ip file. But you wrote you need the profile for inlet / outlet so you don`t require an interpolation file (which is meant for the whole cell zone). Fluent accepts *.prof and *.csv file which might be used as profile at your boundaries.
September 4, 2018 at 5:11 pm
danielc358
SubscriberHow can I use a * .csv file in the inlet and outlet, is there any tutorial that teaches me how to load these files?
Daniel
September 4, 2018 at 5:33 pm
DrAmine
Ansys EmployeeHi,
Here a video.
September 5, 2018 at 6:44 pm
danielc358
I'm trying to load the boundary conditions however the inlet conditions and outlet appear as inlet-contact_region-contact_region_2-src and I can not edit to load a flow rate file, is there a tutorial that teaches how to modify inlet-contact_region-contact_region_2-src so you can edit and upload the file?
Daniel
2706
2142
1355
1144
462
