October 29, 2018 at 4:50 pm
rorti045
SubscriberHi,
I am trying to export my results from Ansys Maxwell to Fluent through the Volume Energy Source toll, however I am unable. I get the following message:
Failed to find an element: and then I get 0 watts on the desired bodies.
I dont know what is causing this issue, since I am able to export my results to transient thermal correctly, but to export them to Fluent is not working.
Many thanks,
Roberto -
October 31, 2018 at 9:11 am
seeta gunti
Ansys EmployeeHello,
Did you check the meshes in FLUENT and Maxwell. For example, the fluent mesh is in cylindrical and maxwell is box shape then exported values at the corner zones will not have any values. This will cause some interpolation error in Fluent and gives you the error. You can try export x,y,z coordinates from ANSYS Fluent to a text file and use this file to export energy source from Maxwell. Hope this will sort out your issue.
Seeta
November 3, 2018 at 5:11 pm
rorti045
SubscriberMany thanks for your suggestion.
The solution was to export the geometry from Maxwell directly into Fluents geometry cell. I was using an intermediate geometry tab where I was adding a few other components, but once I added all my components + the Maxwell geometry in Fluents geometry cell, the problem was solved. -
November 5, 2018 at 7:14 am
seeta gunti
Ansys EmployeeHi,
Glad to know that your problem was solved. Can you make this thread as resolved.
Seeta
2524
2066
1279
1096
457
