July 25, 2018 at 5:36 pm
aerovivek91
SubscriberWhile opening the Ansys fluent 18.2 I am getting this warning
WARNING: No cached password or password provided.
use '-pass' or '-cache' to provide the password
MPI Application rank 0 exited before MPI_Init() with status -1073741511
and after some time I am getting this error
The FLUENT application failed to validate the connection.
Please help me...
July 25, 2018 at 6:55 pm
tsiriaks
Ansys EmployeeHi aerovivek91,
I will assume that you are using Windows 7.
This could be an issue that some Windows update is not installed, specifically KB2533623.
You can verify it by running Fluent in non-graphical mode using this command in the CMD Prompt (change your installation directory accordingly)
"C:Program FilesANSYS IncANSYS Studentv191fluentntbinwin64fluent.exe" ^-r19.1.0 3d -g -meshing
If you see message something like "procedure entry point AddDllDirectory could not be located in dynamic link library KERNEL32.dll" , this means that you are missing that Windows update (KB2533623)
More info about this error is here
https://docs.microsoft.com/en-us/windows/desktop/api/libloaderapi/nf-libloaderapi-adddlldirectory
Thank you,
Win
- Workbench error
- Workbench not opening
- License Error
2524
2066
1285
1096
459
