December 19, 2019 at 4:55 pm
steffenschneider
SubscriberHello Ansys student community,
I'm currently writing my master's thesis using Fluent and I've come across the following problem:
I would like to run my Fluent simulation from a Windows client via RSM on a remote Linux cluster. The connection between client and cluster is established via a VPN tunnel. Client and cluster access two different license servers. The client has access to a local license server, even if there is no VPN connection. The same applies to the cluster. On the cluster, PBS Pro is used as the Job Management System. The setup of RSM on the head node (Athena) and the client was successful (test successful, data transfer successful, ...). If I want to start a simulation from the Workbench (Solution Settings: Submit to Remote Solve Manager, RSM Queue selected, ...) the job is copied to the staging directory and added to the PBS queue (Assign Job ID, Status Running), but when I connect with the assigned Execution Nodes and take a look at the CPU load and processes, no Fluent process is started...
Unfortunately, I did not come up with a useful solution while checking the log data. Only these entries with the job ID were found in the log directory of PBS:
Path: /var/spool/pbs/sched_logs/20191219
[user@athena sched_logs]# cat 20191219 | grep 61192
12/19/2019 14:12:47;0080;pbs_sched;Job;61192.athena;Considering job to run
12/19/2019 14:12:47;0040;pbs_sched;Job;61192.athena;Job run
In the staging directory I also did not find any information in the files.
Do any of you have any idea why the Fluent process is not running? Where can I find more log data that could help me?
Greetings
Steffen -
December 19, 2019 at 6:19 pm
tsiriaks
Ansys EmployeeHi Steffen,
There might be some clue on the RSM Job Report.
On client machine (Windows) , open up RSM Job Monitoring, select the job that has the issue, click on the bottom pane, and right click and save it as html format. See if you can post the entire thing in this forum; otherwise, post the screenshot of the top part of it, as well as looking for the line that say 'final solver command' or 'final cluster command' , something along this line, and post the screenshot of that too.
Thanks,
Win
December 20, 2019 at 6:55 am
steffenschneider
SubscriberHi Win,
tanks for your response. This is the html file from the job. Some of the commands are in german language, I hope that's not a problem.
From line 597, I cut off the other commands. From there on it was only like in the lines before searches for the progress marker.
As you said there are some lines with 'final cluster command' but I can't find 'final solver command'.
Remote Solve Manager Job Report
Job Name:
Cluster Test-DP0-Cluster Test-Lösung (A5)
Owner:
VTPLPPschneider
Submitted:
19.12.2019 14:12:29
Server:
Cluster UMSICHT
Queue:
Umsicht
Final Status:
Unknown
Time
Message
1
19.12.2019 14:12:29
RSM-Version: 19.0.158.0, Erstellungsdatum: 30.11.2017 23:28:28
2
19.12.2019 14:12:29
Job-Name: Cluster Test-DP0-Cluster Test-Lösung (A5)
3
19.12.2019 14:12:29
Typ: Workbench_FLUENT
4
19.12.2019 14:12:29
Client-Verzeichnis: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solution
5
19.12.2019 14:12:29
Client-Maschine: WS-2
6
19.12.2019 14:12:29
Warteschlange: Umsicht [Cluster UMSICHT, umsicht]
7
19.12.2019 14:12:29
Vorlage: Workbench_FLUENTJob.xml
8
19.12.2019 14:12:29
Cluster-Konfiguration: Cluster UMSICHT [10.97.12.10]
9
19.12.2019 14:12:29
Cluster-Typ: PBS
10
19.12.2019 14:12:29
Benutzerdefiniertes Schlüsselwort: leer
11
19.12.2019 14:12:29
Übertragungsoption: NativeOS
12
19.12.2019 14:12:29
Staging-Verzeichnis: \10.97.12.10RSMTempsschneider
13
19.12.2019 14:12:29
Delete Staging Directory: True
14
19.12.2019 14:12:29
Lokales Auslagerungsverzeichnis: leer
15
19.12.2019 14:12:29
Verzeichnis-Zuordnungen:
16
19.12.2019 14:12:29
/home/RSMTemp/sschneider
17
19.12.2019 14:12:29
Plattform: Linux
18
19.12.2019 14:12:29
Konto für entfernten Zugriff: sschneider
19
19.12.2019 14:12:29
Cluster Übergabe-Optionen: leer
20
19.12.2019 14:12:29
Datei-Behandlung: Automatische Eingänge=True, Automatische Ausgänge=True
21
19.12.2019 14:12:29
Normale Eingaben: [*]
22
19.12.2019 14:12:29
Eingaben abbrechen: [sec.interrupt]
23
19.12.2019 14:12:29
Ausgenommene Eingaben: [-]
24
19.12.2019 14:12:29
Normale Ausgaben: [*]
25
19.12.2019 14:12:29
Fehler-Ausgaben: [secStart.log,secInterrupt.verify,SecDebugLog.txt,sec.solverexitcode,sec.envvarvalidation.executed,sec.failure,SecCommPackage.sec]
26
19.12.2019 14:12:29
Ausgaben abbrechen: [secStart.log,secInterrupt.verify,SecDebugLog.txt,SecCommPackage.sec]
27
19.12.2019 14:12:29
Ausgenommene Ausgaben: [hosts.txt,cleanup-fluent-*.sh,sec.interrupt,SecInput.txt,rerunsec.bat,rerunsec.sh]
28
19.12.2019 14:12:29
Abfrage-Dateien:
29
19.12.2019 14:12:29
progress: [status.txt.gz]
30
19.12.2019 14:12:29
transcript: [Solution.trn]
31
19.12.2019 14:12:29
__SecCommunicationPackage: [SecCommPackage.sec]
32
19.12.2019 14:12:29
__SecServerConfig: [ServerConfigFile.conf]
33
19.12.2019 14:12:29
Übergabe in Ausführung...
34
19.12.2019 14:120
Speicherverzeichnis erstellt \10.97.12.10RSMTempsschneiderzwpuadzy.05o
35
19.12.2019 14:120
Job is not active. No need to proceed with inquire operation.
36
19.12.2019 14:123
Laufzeit-Einstellungen:
37
19.12.2019 14:123
Job-Eigentümer: VTPLPPschneider
38
19.12.2019 14:123
Übergabe-Zeit: Donnerstag, 19. Dezember 2019 14:12
39
19.12.2019 14:123
Verzeichnis: \10.97.12.10RSMTempsschneiderzwpuadzy.05o
40
19.12.2019 14:123
Alternatives Plattform-Verzeichnis: /home/RSMTemp/sschneider/zwpuadzy.05o
41
19.12.2019 14:123
File Transfer Package: Upload to localhost:0
42
19.12.2019 14:123
Local Path: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solution
43
19.12.2019 14:123
Remote Path: \10.97.12.10RSMTempsschneiderzwpuadzy.05o
44
19.12.2019 14:123
Files: [*]
45
19.12.2019 14:123
Exclude: [-]
46
19.12.2019 14:123
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solution2019-12-18 - 18-24 - Init.dat
47
19.12.2019 14:123
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solution2019-12-18 - 18-24 - Init.dat to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/2019-12-18 - 18-24 - Init.dat
48
19.12.2019 14:12:42
File size: 101193770 bytes, transferred: 101193770 bytes.
49
19.12.2019 14:12:42
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solutioncommands.xml
50
19.12.2019 14:12:42
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solutioncommands.xml to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/commands.xml
51
19.12.2019 14:12:42
File size: 553 bytes, transferred: 553 bytes.
52
19.12.2019 14:12:42
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionFFF-Setup-Output.cas.gz
53
19.12.2019 14:12:42
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionFFF-Setup-Output.cas.gz to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/FFF-Setup-Output.cas.gz
54
19.12.2019 14:12:43
File size: 6205904 bytes, transferred: 6205904 bytes.
55
19.12.2019 14:12:43
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionFFF.msh
56
19.12.2019 14:12:43
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionFFF.msh to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/FFF.msh
57
19.12.2019 14:12:44
File size: 14437815 bytes, transferred: 14437815 bytes.
58
19.12.2019 14:12:44
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionFFF.set
59
19.12.2019 14:12:44
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionFFF.set to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/FFF.set
60
19.12.2019 14:12:44
File size: 212487 bytes, transferred: 212487 bytes.
61
19.12.2019 14:12:44
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionfluentLauncher.txt
62
19.12.2019 14:12:44
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionfluentLauncher.txt to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/fluentLauncher.txt
63
19.12.2019 14:12:44
File size: 5130 bytes, transferred: 5130 bytes.
64
19.12.2019 14:12:44
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionSecInput.txt
65
19.12.2019 14:12:44
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionSecInput.txt to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/SecInput.txt
66
19.12.2019 14:12:44
File size: 1435 bytes, transferred: 1435 bytes.
67
19.12.2019 14:12:44
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionSolutionPending.jou
68
19.12.2019 14:12:44
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_SolutionSolutionPending.jou to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/SolutionPending.jou
69
19.12.2019 14:12:44
File size: 4160 bytes, transferred: 4160 bytes.
70
19.12.2019 14:12:44
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solutionudfconfig-host.h
71
19.12.2019 14:12:44
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solutionudfconfig-host.h to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/udfconfig-host.h
72
19.12.2019 14:12:44
File size: 4039 bytes, transferred: 4039 bytes.
73
19.12.2019 14:12:44
Hochladen von Datei: H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solutionudf_properties_co2.c
74
19.12.2019 14:12:44
Copying H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestCluster Test_pendingdp0_FFF_Solutionudf_properties_co2.c to //10.97.12.10/RSMTemp/sschneider/zwpuadzy.05o/udf_properties_co2.c
75
19.12.2019 14:12:44
File size: 4434 bytes, transferred: 4434 bytes.
76
19.12.2019 14:12:44
Storage contents:
77
19.12.2019 14:12:44
78
19.12.2019 14:12:44
commands.xml
79
19.12.2019 14:12:44
80
19.12.2019 14:12:44
FFF.msh
81
19.12.2019 14:12:44
FFF.set
82
19.12.2019 14:12:44
fluentLauncher.txt
83
19.12.2019 14:12:44
SecInput.txt
84
19.12.2019 14:12:44
SolutionPending.jou
85
19.12.2019 14:12:44
udfconfig-host.h
86
19.12.2019 14:12:44
87
19.12.2019 14:12:45
122069,73 KB, 11,2 sec (10898,16 KB/sec)
88
19.12.2019 14:12:45
Submission in progress...
89
19.12.2019 14:12:47
Submit Host Version: 19.0.158.0, Build Date: 11/30/2017 11:27:28 PM
90
19.12.2019 14:12:47
Behavior code: Ansys.Rsm.ClusterOperations.Behaviors.WorkbenchFluentBehaviors
91
19.12.2019 14:12:47
Loading Cluster Customization file /application/Ansys/19.0/v190/RSM/Config/xml/ClusterJobCustomization.xml.
92
19.12.2019 14:12:47
No customization found for cluster machineName athena, type PBS
93
19.12.2019 14:12:47
HPC Commands Files Used:
94
19.12.2019 14:12:47
hpc_commands_PBS.xml
95
19.12.2019 14:12:47
Environment variables:
96
19.12.2019 14:12:47
RSM_PYTHON_HOME=/application/Ansys/19.0/v190/commonfiles/CPython/2_7_13/linx64/Release/python
97
19.12.2019 14:12:47
RSM_IRON_PYTHON_HOME=/application/Ansys/19.0/v190/commonfiles/IronPython
98
19.12.2019 14:12:47
RSM_PYTHON_EXE=/application/Ansys/19.0/v190/commonfiles/CPython/2_7_13/linx64/Release/python/runpython
99
19.12.2019 14:12:47
RSM_TASK_WORKING_DIRECTORY=/home/RSMTemp/sschneider/zwpuadzy.05o
100
19.12.2019 14:12:47
RSM_USE_SSH_LINUX=False
101
19.12.2019 14:12:47
RSM_QUEUE_NAME=umsicht
102
19.12.2019 14:12:47
RSM_CONFIGUREDQUEUE_NAME=Umsicht
103
19.12.2019 14:12:47
RSM_COMPUTE_SERVER_MACHINE_NAME=athena
104
19.12.2019 14:12:47
RSM_HPC_JOBNAME=Test_Cluster
105
19.12.2019 14:12:47
RSM_HPC_CORES=3
106
19.12.2019 14:12:47
RSM_HPC_DISTRIBUTED=TRUE
107
19.12.2019 14:12:47
RSM_HPC_NODE_EXCLUSIVE=FALSE
108
19.12.2019 14:12:47
RSM_HPC_QUEUE=umsicht
109
19.12.2019 14:12:47
RSM_HPC_USER=sschneider
110
19.12.2019 14:12:47
RSM_HPC_WORKDIR=/home/RSMTemp/sschneider/zwpuadzy.05o
111
19.12.2019 14:12:47
RSM_HPC_JOBTYPE=Workbench_FLUENT
112
19.12.2019 14:12:47
RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=/application/Ansys/19.0/v190
113
19.12.2019 14:12:47
RSM_HPC_VERSION=190
114
19.12.2019 14:12:47
RSM_HPC_STAGING=/home/RSMTemp/sschneider/zwpuadzy.05o
115
19.12.2019 14:12:47
RSM_HPC_LOCAL_PLATFORM=Linux
116
19.12.2019 14:12:47
RSM_HPC_CLUSTER_TARGET_PLATFORM=Linux
117
19.12.2019 14:12:47
RSM_HPC_STDOUTFILE=stdout.rsmout
118
19.12.2019 14:12:47
RSM_HPC_STDERRFILE=stderr.rsmout
119
19.12.2019 14:12:47
RSM_HPC_STDOUTLIVE=stdout.live
120
19.12.2019 14:12:47
RSM_HPC_STDERRLIVE=stderr.live
121
19.12.2019 14:12:47
RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=/application/Ansys/19.0/v190/RSM/Config/scripts
122
19.12.2019 14:12:47
RSM_HPC_SCRIPTS_DIRECTORY=$AWP_ROOT190/RSM/Config/scripts
123
19.12.2019 14:12:47
RSM_HPC_SUBMITHOST=10.97.12.10
124
19.12.2019 14:12:47
RSM_HPC_STORAGEID=a6f1a9a7-88c8-4857-9878-4cbfc8be78ff LocalOS#\10.97.12.10RSMTempsschneiderzwpuadzy.05o Thursday, December 19, 2019 01:12 0.399 PM
True
125
19.12.2019 14:12:47
RSM_HPC_PLATFORMSTORAGEID=\10.97.12.10RSMTempsschneiderzwpuadzy.05o
126
19.12.2019 14:12:47
RSM_HPC_NATIVEOPTIONS=
127
19.12.2019 14:12:47
ARC_ROOT=/application/Ansys/19.0/v190/RSM/Config/scripts/../../ARC
128
19.12.2019 14:12:47
JobType is: Workbench_FLUENT
129
19.12.2019 14:12:47
Final command platform: AllLinux
130
19.12.2019 14:12:47
131
19.12.2019 14:12:47
132
19.12.2019 14:12:47
Distributed mode requested: True
133
19.12.2019 14:12:47
134
19.12.2019 14:12:47
Running 1 commands
135
19.12.2019 14:12:47
Job working directory: /home/RSMTemp/sschneider/zwpuadzy.05o
136
19.12.2019 14:12:47
Number of CPU requested: 3
137
19.12.2019 14:12:47
AWP_ROOT190=/application/Ansys/19.0/v190
138
19.12.2019 14:12:47
Checking queue umsicht exists ...
139
19.12.2019 14:12:47
External cluster command: queryQueues
140
19.12.2019 14:12:47
Cluster command before expansion: qstat -Q
141
19.12.2019 14:12:47
Final cluster command: qstat -Q
142
19.12.2019 14:12:47
Working directory : /home/RSMTemp/sschneider/zwpuadzy.05o
143
19.12.2019 14:12:47
Variables:
144
19.12.2019 14:12:47
145
19.12.2019 14:12:47
146
19.12.2019 14:12:47
147
19.12.2019 14:12:47
148
19.12.2019 14:12:47
149
19.12.2019 14:12:47
150
19.12.2019 14:12:47
151
19.12.2019 14:12:47
152
19.12.2019 14:12:47
153
19.12.2019 14:12:47
RSM_HPC_CORES=3
154
19.12.2019 14:12:47
155
19.12.2019 14:12:47
156
19.12.2019 14:12:47
157
19.12.2019 14:12:47
158
19.12.2019 14:12:47
159
19.12.2019 14:12:47
160
19.12.2019 14:12:47
161
19.12.2019 14:12:47
RSM_HPC_VERSION=190
162
19.12.2019 14:12:47
163
19.12.2019 14:12:47
164
19.12.2019 14:12:47
165
19.12.2019 14:12:47
166
19.12.2019 14:12:47
167
19.12.2019 14:12:47
168
19.12.2019 14:12:47
169
19.12.2019 14:12:47
170
19.12.2019 14:12:47
171
19.12.2019 14:12:47
172
19.12.2019 14:12:47
True
173
19.12.2019 14:12:47
174
19.12.2019 14:12:47
175
19.12.2019 14:12:47
176
19.12.2019 14:12:47
RSM_HPC_PARSE_MARKER=START
177
19.12.2019 14:12:47
178
19.12.2019 14:12:47
Queue Max Tot Ena Str Que Run Hld Wat Trn Ext Type
179
19.12.2019 14:12:47
180
19.12.2019 14:12:47
umsicht 0 9 yes yes 0 9 0 0 0 0 Exec
181
19.12.2019 14:12:47
rub 0 0 yes yes 0 0 0 0 0 0 Exec
182
19.12.2019 14:12:47
External cluster command: checkQueueExists
183
19.12.2019 14:12:47
Cluster command before expansion: %RSM_PYTHON_EXE% -B -E "%RSM_HPC_SCRIPTS_DIRECTORY_LOCAL%/pbsParsing.py" -queues %RSM_HPC_PARSE_MARKER%
184
19.12.2019 14:12:47
Final cluster command: /application/Ansys/19.0/v190/commonfiles/CPython/2_7_13/linx64/Release/python/runpython -B -E "/application/Ansys/19.0/v190/RSM/Config/scripts/pbsParsing.py" -queues START
185
19.12.2019 14:12:47
186
19.12.2019 14:12:47
Variables:
187
19.12.2019 14:12:47
188
19.12.2019 14:12:47
189
19.12.2019 14:12:47
190
19.12.2019 14:12:47
191
19.12.2019 14:12:47
192
19.12.2019 14:12:47
193
19.12.2019 14:12:47
194
19.12.2019 14:12:47
195
19.12.2019 14:12:47
196
19.12.2019 14:12:47
RSM_HPC_CORES=3
197
19.12.2019 14:12:47
198
19.12.2019 14:12:47
199
19.12.2019 14:12:47
200
19.12.2019 14:12:47
201
19.12.2019 14:12:47
202
19.12.2019 14:12:47
203
19.12.2019 14:12:47
204
19.12.2019 14:12:47
RSM_HPC_VERSION=190
205
19.12.2019 14:12:47
206
19.12.2019 14:12:47
207
19.12.2019 14:12:47
208
19.12.2019 14:12:47
209
19.12.2019 14:12:47
210
19.12.2019 14:12:47
211
19.12.2019 14:12:47
212
19.12.2019 14:12:47
213
19.12.2019 14:12:47
214
19.12.2019 14:12:47
215
19.12.2019 14:12:47
True
216
19.12.2019 14:12:47
217
19.12.2019 14:12:47
218
19.12.2019 14:12:47
219
19.12.2019 14:12:47
220
19.12.2019 14:12:47
RSM_HPC_PRIMARY_STDOUT=Queue Max Tot Ena Str Que Run Hld Wat Trn Ext Type
221
19.12.2019 14:12:47
222
19.12.2019 14:12:47
223
19.12.2019 14:12:47
224
19.12.2019 14:12:47
RSM_HPC_PRIMARY_STDERR=
225
19.12.2019 14:12:47
226
19.12.2019 14:12:47
Executing command: $AWP_ROOT190/SEC/SolverExecutionController/runsec.sh (Fluent)
227
19.12.2019 14:12:47
commands.xml file: /home/RSMTemp/sschneider/zwpuadzy.05o/commands.xml
228
19.12.2019 14:12:47
229
19.12.2019 14:12:47
230
19.12.2019 14:12:47
3
231
19.12.2019 14:12:47
false
232
19.12.2019 14:12:47
0
233
19.12.2019 14:12:47
true
234
19.12.2019 14:12:47
true
235
19.12.2019 14:12:47
236
19.12.2019 14:12:47
237
19.12.2019 14:12:47
%AWP_ROOT190%SECSolverExecutionControllerrunsec.bat
238
19.12.2019 14:12:47
%AWP_ROOT190%/SEC/SolverExecutionController/runsec.sh
239
19.12.2019 14:12:47
240
19.12.2019 14:12:47
241
19.12.2019 14:12:47
242
19.12.2019 14:12:47
commands.xml file END
243
19.12.2019 14:12:47
SecInput.txt file: /home/RSMTemp/sschneider/zwpuadzy.05o/SecInput.txt
244
19.12.2019 14:12:47
#begin
245
19.12.2019 14:12:47
Modifier
246
19.12.2019 14:12:47
SolverTag
247
19.12.2019 14:12:47
Fluent
248
19.12.2019 14:12:47
#end
249
19.12.2019 14:12:47
250
19.12.2019 14:12:47
251
19.12.2019 14:12:47
#begin
252
19.12.2019 14:12:47
InputData
253
19.12.2019 14:12:47
Arguments
254
19.12.2019 14:12:47
--albion --run --launcher_setting_file "fluentLauncher.txt" --fluent_options " -hidden -driver null -workbench-session -i "SolutionPending.jou" "
255
19.12.2019 14:12:47
#end
256
19.12.2019 14:12:47
257
19.12.2019 14:12:47
258
19.12.2019 14:12:47
#begin
259
19.12.2019 14:12:47
Modifier
260
19.12.2019 14:12:47
SystemCouplingParticipant
261
19.12.2019 14:12:47
None
262
19.12.2019 14:12:47
#end
263
19.12.2019 14:12:47
264
19.12.2019 14:12:47
265
19.12.2019 14:12:47
#begin
266
19.12.2019 14:12:47
InputData
267
19.12.2019 14:12:47
NumberOfProcesses
268
19.12.2019 14:12:47
3
269
19.12.2019 14:12:47
#end
270
19.12.2019 14:12:47
271
19.12.2019 14:12:47
272
19.12.2019 14:12:47
#begin
273
19.12.2019 14:12:47
Modifier
274
19.12.2019 14:12:47
ExecutionMode
275
19.12.2019 14:12:47
Parallel
276
19.12.2019 14:12:47
#end
277
19.12.2019 14:12:47
278
19.12.2019 14:12:47
279
19.12.2019 14:12:47
#begin
280
19.12.2019 14:12:47
Modifier
281
19.12.2019 14:12:47
EnableErrorReporting
282
19.12.2019 14:12:47
True
283
19.12.2019 14:12:47
#end
284
19.12.2019 14:12:47
285
19.12.2019 14:12:47
286
19.12.2019 14:12:47
#begin
287
19.12.2019 14:12:47
Modifier
288
19.12.2019 14:12:47
EnableWarningReporting
289
19.12.2019 14:12:47
True
290
19.12.2019 14:12:47
#end
291
19.12.2019 14:12:47
292
19.12.2019 14:12:47
293
19.12.2019 14:12:47
#begin
294
19.12.2019 14:12:47
Modifier
295
19.12.2019 14:12:47
EnableFailureCauseReporting
296
19.12.2019 14:12:47
True
297
19.12.2019 14:12:47
#end
298
19.12.2019 14:12:47
299
19.12.2019 14:12:47
300
19.12.2019 14:12:47
#begin
301
19.12.2019 14:12:47
Modifier
302
19.12.2019 14:12:47
ExpertPropertiesDefined
303
19.12.2019 14:12:47
True
304
19.12.2019 14:12:47
#end
305
19.12.2019 14:12:47
306
19.12.2019 14:12:47
307
19.12.2019 14:12:47
#begin
308
19.12.2019 14:12:47
Modifier
309
19.12.2019 14:12:47
EnableRsmBootstrapping
310
19.12.2019 14:12:47
True
311
19.12.2019 14:12:47
#end
312
19.12.2019 14:12:47
313
19.12.2019 14:12:47
314
19.12.2019 14:12:47
#begin
315
19.12.2019 14:12:47
InputData
316
19.12.2019 14:12:47
AnsysLiStatsValue
317
19.12.2019 14:12:47
41b0e93ac2c14adf89cc263e419504f3
318
19.12.2019 14:12:47
#end
319
19.12.2019 14:12:47
320
19.12.2019 14:12:47
321
19.12.2019 14:12:47
#begin
322
19.12.2019 14:12:47
Modifier
323
19.12.2019 14:12:47
OperationMode
324
19.12.2019 14:12:47
Normal
325
19.12.2019 14:12:47
#end
326
19.12.2019 14:12:47
327
19.12.2019 14:12:47
328
19.12.2019 14:12:47
#begin
329
19.12.2019 14:12:47
InputData
330
19.12.2019 14:12:47
ProductVersion
331
19.12.2019 14:12:47
190
332
19.12.2019 14:12:47
#end
333
19.12.2019 14:12:47
334
19.12.2019 14:12:47
335
19.12.2019 14:12:47
#begin
336
19.12.2019 14:12:47
Modifier
337
19.12.2019 14:12:47
EnableCommunication
338
19.12.2019 14:12:47
True
339
19.12.2019 14:12:47
#end
340
19.12.2019 14:12:47
341
19.12.2019 14:12:47
342
19.12.2019 14:12:47
#begin
343
19.12.2019 14:12:47
Modifier
344
19.12.2019 14:12:47
EnableWriteSolverExitCodeFileOnFailure
345
19.12.2019 14:12:47
True
346
19.12.2019 14:12:47
#end
347
19.12.2019 14:12:47
348
19.12.2019 14:12:47
349
19.12.2019 14:12:47
#begin
350
19.12.2019 14:12:47
Modifier
351
19.12.2019 14:12:47
EnableApplicationBootstrapping
352
19.12.2019 14:12:47
True
353
19.12.2019 14:12:47
#end
354
19.12.2019 14:12:47
355
19.12.2019 14:12:47
356
19.12.2019 14:12:47
#begin
357
19.12.2019 14:12:47
Modifier
358
19.12.2019 14:12:47
CaptureSolverStdout
359
19.12.2019 14:12:47
True
360
19.12.2019 14:12:47
#end
361
19.12.2019 14:12:47
362
19.12.2019 14:12:47
363
19.12.2019 14:12:47
#begin
364
19.12.2019 14:12:47
Modifier
365
19.12.2019 14:12:47
CaptureSolverStderr
366
19.12.2019 14:12:47
True
367
19.12.2019 14:12:47
#end
368
19.12.2019 14:12:47
369
19.12.2019 14:12:47
370
19.12.2019 14:12:47
#begin
371
19.12.2019 14:12:47
InputData
372
19.12.2019 14:12:47
SelectivePluginList
373
19.12.2019 14:12:47
#list
374
19.12.2019 14:12:47
plugins.fluent
375
19.12.2019 14:12:47
plugins.ekm
376
19.12.2019 14:12:47
plugins.common
377
19.12.2019 14:12:47
plugins.usage
378
19.12.2019 14:12:47
plugins.commonErrors
379
19.12.2019 14:12:47
bootstrap.fluent
380
19.12.2019 14:12:47
bootstrap.rsm
381
19.12.2019 14:12:47
bootstrap.ekm
382
19.12.2019 14:12:47
bootstrap.common
383
19.12.2019 14:12:47
#end
384
19.12.2019 14:12:47
385
19.12.2019 14:12:47
386
19.12.2019 14:12:47
#begin
387
19.12.2019 14:12:47
Modifier
388
19.12.2019 14:12:47
Distributed
389
19.12.2019 14:12:47
On
390
19.12.2019 14:12:47
#end -
January 2, 2020 at 10:52 pm
tsiriaks
Ansys Employeesorry for the delay , I was out on vacation.
can you also post the content of "fluentLauncher.txt" in your 10.97.12.10RSMTempsschneiderzwpuadzy.05o or /home/RSMTemp/sschneider/zwpuadzy.05o . If it doesn't exist anymore, open RSM Configuration 19.0 -> File Management -> check the box that says "Keep job files in staging directory when job is complete" , then resubmit the job and post the content of "fluentLauncher.txt" in the new staging folder.
Additionally, what happens if you change the file transfer option to RSM Internal File transfer, then only specify the staging directory on the Linux cluster (/home/RSMTemp/sschneider/) and make sure that you open your Workbench-Fluent project from under C:Temp director
Is VPN always required to connect to the network ? If possible, I would say it's best to try connecting 'directly' to the network without going through VPN, at least for now to minimize any potential issue with using VPN.
Thanks,
Win
January 7, 2020 at 12:15 pm
steffenschneider
SubscriberHey Win,
no big deal.
I have resubmitted the job an this is the content of "fluentLauncher.txt":
[double_precision]
num=1
double_precision-0=1
last=1
select=0
[init_pcontrolled]
num=1
init_pcontrolled-0=0
last=0
select=0
[init_use_case]
num=1
init_use_case-0=0
last=0
select=0
[init_use_data_file]
num=1
init_use_data_file-0=1
last=1
select=0
[init_data_file]
num=1
init_data_file-0=H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestInitialization2019-12-18 - 18-24 - Init.dat
last=H:Masterarbeit - Steffen SchneiderFluent SimulationTest FilesCluster TestInitialization2019-12-18 - 18-24 - Init.dat
select=0
[check_no_show_again]
num=1
check_no_show_again-0=0
last=0
select=0
[check_m]
num=1
check_m-0=1
last=1
select=0
[check_egw]
num=1
check_egw-0=1
last=1
select=0
[check_wcs]
num=1
check_wcs-0=1
last=1
select=0
[check_act]
num=1
check_act-0=0
last=0
select=0
[check_scheduler]
num=1
check_scheduler-0=0
last=0
select=0
[fluent_inc_path]
num=1
fluent_inc_path-0=C:Program FilesANSYS Incv190fluent
last=C:Program FilesANSYS Incv190fluent
select=0
[check_journal]
num=1
check_journal-0=0
last=0
select=0
[journal_file]
num=1
journal_file-0=
last=
select=0
[check_setup_udf]
num=1
check_setup_udf-0=1
last=1
select=0
[udf_ntx86]
num=1
udf_ntx86-0=C:Program FilesANSYS Incv190fluentntbinntx86udf.bat
last=C:Program FilesANSYS Incv190fluentntbinntx86udf.bat
select=0
[udf_win64]
num=1
udf_win64-0=C:Program FilesANSYS Incv190fluentntbinwin64udf.bat
last=C:Program FilesANSYS Incv190fluentntbinwin64udf.bat
select=0
[pre_post_only]
num=1
pre_post_only-0=0
last=0
select=0
[proc_serial]
num=1
proc_serial-0=0
last=0
select=0
[check_parallel_options]
num=1
check_parallel_options-0=0
last=0
select=0
[meshing_numproc]
num=1
meshing_numproc-0=1
last=1
select=0
[numprocessors]
num=1
numprocessors-0=10
last=10
select=0
[numgpgpus]
num=1
numgpgpus-0=0
last=0
select=0
[interconnect]
num=1
interconnect-0=default
last=default
select=0
[mpi_type]
num=1
mpi_type-0=default
last=default
select=0
[local_shared_memory]
num=1
local_shared_memory-0=0
last=0
select=0
[check_machine]
num=1
check_machine-0=0
last=0
select=0
[radio_machine_list]
num=1
radio_machine_list-0=0
last=0
select=0
[radio_machine_file_name]
num=1
radio_machine_file_name-0=1
last=1
select=0
[machine_list]
num=1
machine_list-0=
last=
select=0
[machine_file]
num=1
machine_file-0=W:machine_names_UMSICHT.txt
last=W:machine_names_UMSICHT.txt
select=0
[check_cache_password]
num=1
check_cache_password-0=0
last=0
select=0
[always_convert_to_unc]
num=1
always_convert_to_unc-0=0
last=0
select=0
[ccp_head]
num=1
ccp_head-0=10.97.12.10
last=10.97.12.10
select=0
[job_template]
num=1
job_template-0=
last=
select=0
[node_group]
num=1
node_group-0=
last=
select=0
[unit_core]
num=1
unit_core-0=1
last=1
select=0
[unit_socket]
num=1
unit_socket-0=0
last=0
select=0
[unit_node]
num=1
unit_node-0=0
last=0
select=0
[check_start_until_allocated]
num=1
check_start_until_allocated-0=1
last=1
select=0
[check_xml]
num=1
check_xml-0=0
last=0
select=0
[xml_file]
num=1
xml_file-0=
last=
select=0
[check_LSF]
num=1
check_LSF-0=0
last=0
select=0
[check_SGE]
num=1
check_SGE-0=0
last=0
select=0
[check_PBSPro]
num=1
check_PBSPro-0=1
last=1
select=0
[use_lsf_queue]
num=1
use_lsf_queue-0=0
last=0
select=0
[lsf_queue]
num=1
lsf_queue-0=
last=
select=0
[use_lsf_checkpoint]
num=1
use_lsf_checkpoint-0=0
last=0
select=0
[check_checkpoint_driectory]
num=1
check_checkpoint_driectory-0=0
last=0
select=0
[checkpoint_driectory]
num=1
last=
select=0
[check_checkpoint_period]
num=1
check_checkpoint_period-0=1
last=1
select=0
[checkpoint_period]
num=1
checkpoint_period-0=60
last=60
select=0
[sge_qmaster]
num=1
sge_qmaster-0=localhost
last=localhost
select=0
[sgeq]
num=1
sgeq-0=
last=
select=0
[sgepe]
num=1
sgepe-0=
last=
select=0
[use_sge_settings]
num=1
use_sge_settings-0=0
last=0
select=0
[sge_settings]
num=1
sge_settings-0=
last=
select=0
[check_remote_linux]
num=1
check_remote_linux-0=1
last=1
select=0
[remote_fluent_inc_path]
num=1
remote_fluent_inc_path-0=/application/Ansys/19.0/v190/fluent/
last=/application/Ansys/19.0/v190/fluent/
select=0
[rsh_rsh]
num=1
rsh_rsh-0=1
last=1
select=0
[rsh_ssh]
num=1
rsh_ssh-0=0
last=0
select=0
[rsh_other]
num=1
rsh_other-0=0
last=0
select=0
[check_rhost]
num=1
check_rhost-0=1
last=1
select=0
[rhost_name]
num=1
rhost_name-0=10.97.12.10
last=10.97.12.10
select=0
[check_remote_work_dir]
num=1
check_remote_work_dir-0=0
last=0
select=0
[remote_work_dir]
num=1
remote_work_dir-0=
last=
select=0
[rsh_other_command]
num=1
rsh_other_command-0=
last=
select=0
[dim_2d]
num=1
dim_2d-0=1
last=1
select=0
[dim_3d]
num=1
dim_3d-0=0
last=0
select=0
[env_list]
num=0
I will change the file transfer option right now and let you know what happens.
Unfortunately the VPN is always required. I don't have any other option to connect to the network.
Steffen
January 8, 2020 at 9:46 pm
tsiriaks
Ansys EmployeeLet us know if changing file transfer option makes a difference.
If not, keep the RSM Internal File transfer option but also try putting your local project file (where Workbnech is launched from) under C:Temp
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5328
3311
2471
