Fluent keeps crashing when changing b-c using TUI command
    • Jad Diab
      I am trying to change the boundary condition using a TUI command (to be used in schemes later on), but fluent keeps crashing when I using the "()" brackets to end the list when choosing the zones to specify the boundary condition on, did anyone face this problem before?
      the TUI command: define/boundary-conditions/set/wall/ce2 ()/uds/no/500
      Thank you in advance
      Try
      /define/boundary-conditions/set/wall/ce2 () /uds/no/500
      I've added a / at the start & a space after /   Otherwise run through the command piece by piece to see what's going on. Ie
      /set
      /wall
      ce2
      /uds
      etc
      You're looking to see what's complaining. I assume you've already assigned UDS in the User Defined panel?
