June 23, 2021 at 5:00 am
ray1989
SubscriberI have installed Ansys student version 2021 R1. I am able to open the workbench, set up a model and run it. However, fluent launcher is not visible in the start menu unlike workbench. Hence, I am not able to open the case files. Could you please help to resolve the issue?
Thanks
June 23, 2021 at 11:05 amANSYS_MMadore
Ansys EmployeePlease share a screenshot showing your full "ANSYS 2021 R1" Windows Start menu. Please paste it into your comment, do not attach it as we cannot download attachments.
June 23, 2021 at 11:37 amJune 23, 2021 at 11:46 amJune 23, 2021 at 12:25 pmJune 23, 2021 at 12:37 pmANSYS_MMadore
Ansys EmployeeDo not type in the Search. Click the Windows Start Menu button. What do you see under the Windows Start Menu for installed applications? What version of Windows do you have installed? For example, clicking the WIndows Start Menu, NOT typing in the Search field, you will see all your installed programs.
June 23, 2021 at 12:45 pmJune 23, 2021 at 12:52 pmANSYS_MMadore
Ansys EmployeeIf you installed the Student 2021R1 product you should see Fluent in the list if you scroll down past EnVideo.
June 23, 2021 at 1:39 pmJune 23, 2021 at 1:47 pmANSYS_MMadore
Ansys EmployeePlease try running C:\Program Files\ANSYS Inc\ANSYS Student\v211\ProductConfig.exe by right-clicking and selecting Run as Administrator. Select Configure Products & CADs, then select all products and configure. Please let me know if that populates the start menu with the missing FLUENT entries.
June 23, 2021 at 2:02 pmJune 23, 2021 at 2:17 pmANSYS_MMadore
Ansys EmployeeSomehow during the install it missed some of the configurations. Can you go to C:\Program Files\ANSYS Inc\ANSYS Student\v211\commonfiles\configs\winx64\config and run the AnsConfigFLUENT.exe, using right-click -> Run as administrator? That should add it to your Start Menu.
June 23, 2021 at 2:36 pmray1989
SubscriberThank you. Now Fluent appears .
January 15, 2022 at 7:00 am22503862
SubscriberHow did you fix this?
January 15, 2022 at 12:45 pmray1989
SubscriberI followed the steps suggested in this thread
February 19, 2022 at 5:35 pmp8hardin
Hi I have the same problem and I tried to follow the steps suggested but when i click on ProductConfig.exe and click on run as administrator nothing happens. Do you run ProductConfig.exe before intalling ansys or after the installation of the software?
Thanks
February 21, 2022 at 11:50 amANSYS_MMadore
Ansys EmployeeYou run it AFTER the installation.
Viewing 16 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
3694
2564
1765
1236
592
