Systems
Systems
Fluent learn
    • LorenzoSGRT
      Good day and thanks for the help
      We have downloaded Ansys 2019 and Ansys 2019-R3, we must perform a CFD of a motorbike and in Ansys 2019 we used a SIMPLE solver method but in Ansys 2019R3 if we use the same method appers a turbolent viscosity error that exceed the limt. We check the setting and it is the same. Is there any advice about it ?
      Best regards
      SGRT
      Work out what's causing the issue (it's a warning and not an error) and revise the settings: I'd stat with the inlet boundary conditions. Otherwise just increase the limits a bit; for external HVAC (ie flow around a city) I tend to use 1e14 to allow the turbulence to sort itself out.
