Fluent meshing error
    • javdijaj
      I am trying to generate the surface mesh of 3D geometry and I am getting this error:
      Error: fromScheme: int64_t
      Error Object: #f
      Does anyone have an idea how to fix it ?
      Thank you in advance.
      J.Avdijaj
    • Keyur Kanade
      Please check geometry in SpaceClaim.
      Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
      The geometry should be error free to proceed.
      If geometry has any errors, please modify/recreate geometry at those places.
      Please check following videos
      Fluent Meshing Watertight Workflow:
      https://www.youtube.com/watch?v=aBxbYRVoRLo
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
    • javdijaj
      Hi Mr. Kanade,
      Thank you, it solved that problem.
      Unfortunately, there is another error now.
      Error: After Surface Mesh, the model consists of 8 free nodes that could not be repaired. The CAD needs to be repaired before proceeding.
      Error Object: #f
      Would you know how to solve that too ?
      J.Avdijaj
    • Keyur Kanade
      This could be related to geometry or this could be related to sizing.
      Please check your geometry if you have any edges connected to only one face.
      Also check sizing. Giving correct sizing is key to successful meshing.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/tgd_user_workflow_guided_tasks_setup_mesh_controls.html?q=curvature%20sizing
      Please go through help manual for more details
      Keyur
Viewing 3 reply threads
