Preprocessing
Preprocessing
Fluent Meshing strange mesh
    • sianov
      Hi
      I have a problem with mesh. I'm using Fluent Meshing to generate mesh of FS vehicle. I use poly-hexcore mesh. When I set 0,1mm thickness of first prism layer then mesh is good, but when I set 0,012 mm then it is very bad mesh. I include screenshot of mesh. Poly elements look like they are split in few elements. Has anyone idea how to solve it?
    • Keyur Kanade
      can you please insert images? we as ansys employee can not download attachments.
    • sianov
      Mesh with 0,012mm first prism
    • Keyur Kanade
      yes, this is done to keep good orthogonal quality.
      when there are such curvatures with very small first prism layer height, the cells are splitted to avoid bad quality of cells.
      there was a old command
      (tgsetvar! 'poly/split-thin-poly-prism-cell? #f)
      check if this works for you.
      use this command before generating prisms.
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • sianov
      Mesh with 0,1mm first prims.
Viewing 4 reply threads
