Fluent MSMD Battery Model
    • 2Undertaker
      Hi, I'am using Fluent to model a battery, i selected the MSMD battery model. The problem is that it only shows up active and passive components in the conductive zones window, the options for tab components and busbar components does not appear. I set the cell as active and the positive tab zone and negative tab zone both as passive, but when i try to configurate the materials the UDF Diffusivity does not apper in the properties window, because of that i can't configurate correctly the materials. At first i was thinking that the simulation would work with the tabs zones set as passive instead of tabs, but i think that maybe the absence of the UDF Diffusivity in the materials properties has something to do with the configuration in the conductive zones. Besides that the simulation that i need involves more than one cell, so i need the busbar component option. Does anyone knows how can i make the tab and busbar options appear in the conductive zone window?
    • RK
      Can you please make sure the busbar and tab components are being into Fluent? Go to mesh display and check. If not, you might have to revisit the geometry or meshing.
    • 2Undertaker
      Thanks for the answer Sir. Yes the components are in the mesh display list.
      I tried the configuration with 3 cells and 2 busbar but also didin't work.
      The problems with the materials properties persists. If you have any suggestions on how i could fix this i would appreciatte. Thanks.
    • TSKhanh
      Hi 2Undertaker Can you give me show that you address your above issue?
    • antoniodwp
      Hi 2Undertaker It seems like you are using Ansys Student Version
Viewing 4 reply threads
