January 21, 2022 at 6:13 pm
dzaki8598
SubscriberHi,
I am trying to simulate a steady-state 2D flow with natural/free convection. As an example, this is the schematic of the simulation. It is a 3x3 room with a solar chimney. The pressure inlet is on the right hand side of the picture. The heat flux comes from the left side of the picture (below is a velocity contour, the heat comes from the high velocity surface side in the picture)
January 22, 2022 at 8:25 amdzaki8598
Subscriber(EDIT)
I have managed to reach the steady solution. Apparently, in some cases it is recommended to not initialize the natural convection simulation using forced convection simulation first. Now, I have reached stable residuals and the monitors (volume average velocity and temperature) are almost very steady, also the contours are the same as the results with the forced convection initialization.
January 24, 2022 at 9:52 amRob
Ansys EmployeeGood to hear.
As an aside, natural convection flows tend to exhibit transient behaviour so the solver may struggle to get a single steady result. However, the variation in the flow with time is small so we often use the steady solver with monitors to confirm the flow field is converged: residuals tend to get stuck before reaching convergence.
January 31, 2022 at 12:22 pmdzaki8598
SubscriberThank you for your answer, Rob.
Also, I want to add that the continuity residual of my simulation may not have reached convergence (although it's going stable), but from the monitors the volume average velocity has steadied. As for the volume average temperature, the monitor hasn't been as steady as the velocity monitor, although the difference of value between each iteration is very small (but the graph is still increasing at a relatively low rate.
Although that may be the case, I have validated my simulation using a reference paper, and surprisingly it shows a very agreeable results with the paper!
So, is my simulation good enough now in order for me to analyze the physics?
Thank you
Regards Dzaki
January 31, 2022 at 1:53 pmDrAmine
Ansys EmployeeIf the monitors plotted over the iterations are not changing anymore towards the end of time step then you probably reached steady state. I always recommend doing mesh and time step sensitivity analysis to verify the methods but I will keep that decision to you!
January 31, 2022 at 1:54 pmDrAmine
Ansys EmployeeAnd natural convection are inherent unsteady: even if you are lucky with steady solver you should see that as a best practice!
January 31, 2022 at 1:55 pmDrAmine
Ansys EmployeeYou residual plot are bad, though. Can you add screenshots of your mass and heat flux reports. Thanks!
Viewing 6 reply threads- You must be logged in to reply to this topic.
5290
3311
2471
