June 30, 2020 at 6:04 pm
keshavananth
SubscriberHi,
I followed a similar thread posted a few days earlier, but my error is slightly different. When I launch the setup stage in Fluent, the application fails. I have reinstalled the program three times and ran it as an admin when reinstalling. I have attached screenshots from the console.
Please let me know what I should do and thanks for your help!
- Keshav
July 1, 2020 at 10:46 am
Ansys EmployeePlease post the screen shot in with the text as staff are not permitted to open or download attachments.
July 1, 2020 at 3:06 pm
July 3, 2020 at 1:10 am
tsiriaks
Ansys EmployeeYou are also having some MPI issue.
What steps did you follow from other thread ? Did you set some MPI environment variables ? It could be that you set wrong values.
Is this the same error as your original error before applying any suggestion on here ?
You can try Fluent Launcher, click more options -> parallel -> select MPI type to be MS-MPI and check the box to specify IP address to be 127.0.0.1
July 7, 2020 at 4:33 pm
keshavananth
SubscriberI hadn't tried anything in specific, only read over the thread. I will try the suggestion made above and report back.
July 7, 2020 at 4:57 pm
July 9, 2020 at 3:11 pm
keshavananth
SubscriberAny updates on this problem? Thanks!
July 9, 2020 at 9:07 pm
tsiriaks
Ansys EmployeeThis issue is likely Firewall or Anti-virus or some issue with local networking on your machine (such as using VPN)
If you have full control on these, you can do a quick test by turning all of them off and see if it makes a difference. If so, you can enable them back but just add the correct exceptions/exclusions.
July 11, 2020 at 5:14 pm
keshavananth
SubscriberI was able to disable my Anitvirus and run the software, this prompted the Windows defender prompt to pop up, where I was able to allow the software to run. Fluent is up and running. Thanks for your help!
July 13, 2020 at 11:30 pm
tsiriaks
Ansys EmployeeThat's great ! If you want , you can turn on your Anti-virus again but just add exclusions to those executable's or folders.
If you are good for now, please mark this post as 'Is Solution' , so we know it's been addressed.
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3850
2609
1853
1246
600
