March 24, 2022 at 3:28 pm
soloviev
SubscriberHello,
We have previously used profiles to load data into boundaries in Fluent 2020 and previous. Now that we have switched to 2022R1 the profiles are now having name issues. When reading profiles the name goes to '----' (preview not available) for all profiles I load, and therefore the old one is overwritten by any new ones that are read. I checked the 2022 user guide to check if formatting has changed and it hasn't according to the guide the format should be as follows for .csv profiles:
[Name]
name
[Data]
x,y,z,velocity
insert data here....
This is the same format we used previously but now when it is loaded the issue above happens.
Thanks,
Alex
March 24, 2022 at 4:43 pmRob
Ansys EmployeePlease can you post some screen shots?
March 24, 2022 at 8:26 pmMarch 25, 2022 at 9:47 amDrAmine
Ansys EmployeeI cannot reproduce the issue with the name in 22R1.
I copied the example from the documentation and put it in a file. Can you try that?
March 25, 2022 at 3:30 pmRob
Ansys EmployeeThe example is comma delimited, https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/flu_ug_sec_bcprof_format.html can you check you've not conflated two profile syntax styles? I assume you've not pushed the text straight to Linux without doing "dos2unix" on the Linux side?
March 25, 2022 at 7:45 pmsoloviev
SubscriberThank you Rob and DrAmine. I found that when you specified comma delimited that there were extra commas when the profile was loaded in a text editor as compared to excel, which didn't show these extra commas. When they were removed the name was read in correctly.
Thanks Alex
March 28, 2022 at 2:20 pmRob
Ansys EmployeeMicrosoft 1, User 0. :) Thanks for letting us know.
Viewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
7748
4504
2971
1449
1322
