August 7, 2022 at 3:30 am
tyyang
SubscriberHi all,
I'm working on some two-phase inertia-driven flow simulations. I check the contour plot right after the simulation finished, and the result looks correct (left picture).
However, once I turn off and open the fluent again. The result looks very different and looks wrong (right picture). CFD-post also shows the wrong result.
Does anyone know how to solve this?
Thanks.
August 8, 2022 at 3:21 am
Keyur Kanade
Ansys EmployeePlease use same min and max while displaying contours.
Keyur
August 8, 2022 at 2:41 pm
August 8, 2022 at 4:56 pm
Nikhil Narale
Ansys EmployeeFor me, it looks like the case is not solved. Did you read the data file after re-opening fluent? Can you please check?
Nikhil
- The topic ‘Fluent result changes after reopening it’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
