June 17, 2019 at 7:19 pm
Hussein13
SubscriberHello,I'm doing an aerodynamics analysis on vehicle using fluent.
I completed calculations and got a very fair results.
The problem is i couldnt find the iteration history for the scaled residuals, i saved the whole project and the fluent setup but i cant find the details anywhere.
I managed to find the results for the CD and CL but the scaled residuals aee missing.
Can anyone help?
Thank you.
P. S : a iteration history for the cd is attached and i want the same for the scaled residuals. -
June 17, 2019 at 7:34 pm
DrAmine
Ansys EmployeeGo under residual's and plot. I guess only last 1000 iteration are stored if you did not change the default behavior.
June 17, 2019 at 11:08 pm
Hussein13
SubscriberGo under residual's and plot. I guess only last 1000 iteration are stored if you did not change the default behavior.
Thank you amine Yes, i know how to plot the residuals. But the thing is i need the data which is used for plotting the graph, so i can use it in another program. I need it as a txt file or something similar, -
June 18, 2019 at 4:56 am
DrAmine
Ansys EmployeeOkay. I do remember that writing option has been dropped. You need to initiate it from beginning. I need to check -
June 18, 2019 at 2:31 pm
Hussein13
SubscriberOkay. I do remember that writing option has been dropped. You need to initiate it from beginning. I need to check
Yes, there is NO writing option for the scaled residuals. But, as d long as the fluent is able to plot it. Then the data must be there somewhere. I can't really do the calculation all over again. I would really appreciate if you could help me out.
Thanks again. -
June 18, 2019 at 2:44 pm
DrAmine
Ansys EmployeeIn Fluent console:
1) /plot/residuals-set ptf then give a name for the file
2) /plot/residuals
Then select the equations which will be written in the file. You can then read back the file into Fluent to plot it or use elsewhere!
June 18, 2019 at 4:48 pm
Hussein13
SubscriberIn Fluent console:
2) /plot/residuals
I will give it a try and tell you what happens.
Thank you sir. -
June 19, 2019 at 6:52 am
DrAmine
Ansys EmployeePlease update then and mark the solution provided as the "answer" and the topic as "Is solved".
June 19, 2019 at 4:18 pm
Hussein13
SubscriberPlease update then and mark the solution provided as the "answer" and the topic as "Is solved".
Thank you sir.
Anyway i can get the iteration's CP HISTORY, I have the Cd values but i only need the cp and the viscous coefficient as separate values not as a sum.
Thanks again.
3744
2573
1793
1236
594
