Ansys Free Student Software
Fluent Setup not working
    • Shreyansh Jangitwar
      When I try to open it after meshing and importing geometry it shows "Ansys is unable to validate the connection"
    • Kishan Konannavar
      Hello
      There are couple of older posts with the same problem, did you happen to go through them?
      The Fluent application failed to validate the connection, what to do? (ansys.com)
      Fluent Failed to validate connection (ansys.com)
      Which version of Ansys student are you facing this issue with? Does the same happen with other versions?
      Thank you
      Yes, I went to the previous post but could not find anything helpful. I am using ansys 2023 R1 student version.
      • Kishan Konannavar
        Did you try installing and launching a different version other than 2023R1?
