fluent setup:error occure
    • veera
      Dear sir
      i am simulating the In-cylinder (ic engine simulation) , with dynamic mesh (hybrid mesh), with DPM (diesel liquid), and species (diesel-air)
      i am using k-e rng -eddy dissipation with volumetric.
      initial conditions: chamber pressure 70bar and 713k
      DPM injection from the surface with 183 m/s  for the crank angle of 337-350 - in boundary condition i kept that surface as the wall with escape
      i am facing following errors
      1. invalid cp (1.000000+00) for species (ex:nitrogen, diesel-air) zero (k)nan
      2.turbulent viscosity limited to viscosity ratio of 1.000000e+5 for cell xxx (near half the total cell)
      3.divergence detected in AMG solver: temperature
       4. Temperature limited to 1.0000e+5in xxx cellson zone domain xx
      Try with constant material properties for cp, k etc and see how it behaves. Have you got the mesh working yet?
    • veera
      no sir, it's not happening, in layer sets, I tried the height with split factor1 also, but it's not happening.
      pls try to give answers for above all the questions
      questions 2, 3, 4
    • veera
      hi sir, i run with a constant value, see initially i am started the problem with invalid cp in n2 , if i modify range in material parameters , after few itteration its showes invalid cp in diesel-air mixture
      n2
      h20
      co2
      o2
      this are my mixtures
      suppose, i switch off  species and DPM model, the dynamic mesh is working properly with solution converged
      pls help me to resolve this problem
      4 will cause 1 and which likely triggers 3.  2 may be related to 4 but may also be boundary condition or settings related.
      If the mesh runs OK try it with single phase, does it work, and is the mesh skew good enough?
Viewing 4 reply threads
