December 19, 2022 at 11:24 pm
jcastel
Subscriberi have a workbench project containing a Fluent job which is set up to run in several stages using the " Automatically Initialize and Modify Case" functionality under "Manage...".
When I submit the job from the Fluent GUI, all the "Pre-initialization" commands run fine and the solution runs fine. So i know there is not an issue with the job itself.... However, when I clear generated data then, update the same Fluent job from the workbench interface, all the "Pre-initialization" commands appear to run fine and the same case is initialized the same way but then I get a "Divergence detected in AMG solver: " error.
What could cause the solver to run differently when started in the GUI as opposed to from Workbench?
December 28, 2022 at 12:59 pm
Essence
Ansys EmployeeHello,
Divergence can be obtained due to number of factors. You may find more information about the AMG solver here: 32.5. Setting Algebraic Multigrid Parameters (ansys.com) 32.3. Pressure-Based Solver Settings (ansys.com)
2688
2138
1355
1140
462
