Fluent Spalart-Allmaras QCR model
    • hz8n21
      I noticed the corner flow correction in the theory guide (Eqn 4.405) is not the same as the original QCR2000. When I expanded the last term out the results does not match with each other. Not sure why the sign changed?
      Kind Regards,
      Huining
    • DrAmine
      Can you add some more information? What is different?
    • hz8n21
      The equation on the top is Eqn 4.405 in the theory guide. Another equation is the original QCR2000. The difference is the signs in the bracket terms which are highlighted in the red circle.
