Fluent-Static Structural – Fluid Solid Interface Named Selection
    • shehab Gamrah
      Dear all,
      I have a problem that I couldn't solve for the past 4 weeks regarding named selection and FSI. I have a solid model that is complex and I can only create nodal or elemental named selection, however for importing pressure in static structural it works only with a face named selection, so can anyone tell me how to create the face named selection or use nodal named selection for the fsi.
    • 1shan
      Which workbench version are you using? In your last post - https://forum.ansys.com/discussion/28051/ansys-mechanical-named-selection#latest - I suggested you to import pressure using external data, select all external faces and then use the filter option to select the nodal named selection. Can you explain what issues are you facing in this workflow?
      Regards Ishan.
    • shehab Gamrah
      hello thanks, I have tried this and it didn't work. its 19.3. problem is I can create nodal named selections, but can't apply imported pressure on them.
