May 29, 2022 at 12:54 am
May 29, 2022 at 6:04 am
kevin1986
SubscriberUpdate: I found even I run it on one node, it still has such issue.
May 30, 2022 at 7:10 am
DrAmine
Ansys EmployeeCan you benchmark a couple of iterations and check if the residuals are smooth? Which models are involved? Disable all I/O and benchmark again.
May 30, 2022 at 9:35 am
kevin1986
SubscriberHi, this is a simple single-phase flow in a duct. Actually it is used for test the server performance. Therefore all I/O is disabled. The thing is that it happens when the residuals are very small. Since we just want to test the server performance. Even the residuals are quite small we still run it for long, which may seems to be odd. Then we notice such problem.
3736
2570
1783
1236
594
