Ansys Free Student Software
Fluent take long time to browse files
    • louai
      Dear
      i recently faced an issue with Ansys Fluent
      when trying to browse files from the file tap it takes so long just to go from a folder to another
      is there any fix to this problem knowing that i have tried to uninstall and install but it does not solve the problem
      thanks
      I've not seen that. Are you looking on the local disc or over a network? I assume you have space on the local disc and aren't using the RAM & cpu for something else?
    • louai
      Dear Rwoolho
      thanks for the prompt reply
      i am running fluent in my laptop and have plenty of disc space as well , Ram and CPU low usage
      i do not think is because of the Ram or CPU since it runs the simulations in serial and parallel without issue
      i have checked the firewall as well and no thing regarding Fluent is deactivated
      any idea what is causing that
      regards
      Are all panels slow, or just those looking at files?
    • louai
      Dear
      i managed to solve the problem
      after searching on the net it was advised to disable certain third party extensions , i did so and fluent back to normal and is working fine now
      what surprised me is why only fluent was affected and workbensh , design modeler and mesh were fine
      anyway problem was solved and thank you so much for your follow up
      regards
      Which extension?
      Fluent is UNIX based so may well interact with 3rd party tools in a different way to Workbench which was developed on Windows.
    • louai
      Dear
      really not sure which extension
      i follow a blog on the net where people mentioned that some extension added to right click list menu will cause same thing for different processes
      the blog was not specific to Fluent but once i disabled those extensions Fluent back to normal , but what surprised me is just Fluent got unstable but if work from workbench every thing was ok.
      i would like to report that the issue is solved
      sorry for any inconvenience and thanks for your help
      No worries. I was curious as to what you were running to let DEV & IT know to see if we can do something about it for 2021.
Viewing 7 reply threads
