Fluent temperature and pressure
    • AjibAkmal21
      can anyone help me, this uses fluent but the temperature goes up instead the pressure goes down?
      What am I looking at?  Has the solution converged? What is the fluid density?
      • AjibAkmal21
        it has converged, I use a density with a value of 855 kg/m3. what happens in the simulation is that the temperature value increases but the pressure value decreases.
        which should happen when the pressure value increases, the temperature value also increases.!! are there any settings that affect the temperature and pressure values?
        nb: for boundary conditions according to the desired value.
      If the density is constant why would pressure alter temperature?
