Ansys Products
Ansys Products
Fluent through VPN not working, how to fix?
    • SaraB
      Hello, I am trying to use my university academic license by connecting through a Cisco VPN, but unfortunately Fluent is not working for me.
      I installed Ansys 2020R2 (full version, not student) and added the license server IP in the anslic_admin utility.
      Initially, when I tried to run Fluent I got this message:
      ANSYS LICENSE MANAGER ERROR: Capability Fluent Solver does not exist in the ANSYS licensing pool.
      No specified user license preferences match available products in the specified license path:
      ANSYSLI_SERVERS: [email protected]
      FLEXlm Servers: [email protected]
      Hit return to exit.
      Unexpected license problem; exiting.
      I tried to follow some of the suggestions I found on the forum and now this is what happens:
      -standalone Fluent doesn't give me any errors, however it does not load completely and I have to kill the process via task manager.
      -if I try to open Fluent from Workbench it opens very briefly saying "Unable to connect to external socket: Error during socket creation", then it closes with the message "The Fluent application failed to start"
      Here's what I tried so far:
      -checked that the ports 1055 and 2325 are open
      -checked for firewalls
      -deleted license preferences in %appdata%
      -added the following on the ansyslmd.ini file:
      ANSYSLI_TIMEOUT_FLEXLM=15
      ANSYSLI_FNP_IP_ENV=1
      ANSYSLI_FLEXLM_TIMEOUT_ENV=15000000
      When I run the license status diagnostic I get the following message:
      Jul 08, 2021 12:53: Attempting to display the license status...
      DISPLAY THE LICENSE STATUS:
      ANSYS Licensing Interconnect path = [email protected]
      ANSYS FLEXlm license path = [email protected]
      ***** Note: Due to a FLEXlm limitation, all tasks may not be found *****
      ***** LICENSE SERVER STATUS: [email protected] *****
      lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
      Flexible License Manager status on Thu 7/8/2021 12:53
      [Detecting lmgrd processes...]
      License server status: [email protected]
        License file(s) on mme144011: C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.lic:
       mme144011: license server UP (MASTER) v11.16.5
      Vendor daemon status (on mme144011):
       ansyslmd: UP v11.16.5
      Feature usage info:
      Users of 1spacdes: (Total of 550 licenses issued; Total of 0 licenses in use)
      Users of a_catv6_reader: (Total of 550 licenses issued; Total of 0 licenses in use)
      etc...
      Could you please help me solve this issue?
      Thank you very much!
      Sara
    • George Karnos
      Hello Sara On the license server the daemon ansyslmd will be using a port also.
      This port should also be opened in the firewall exceptions.
      We recommend that if firewalls are in play that the license file be edited to give ansyslmd a static port as by default it is dynamic.
      The vendor line can be changed as follows to give the ansyslmd a static port of 1056
      VENDOR ansyslmd PORT=1056
      once edited and saved, the license manager would need to be restarted and 1056 would need to be added to all firewall inbound and outbound exceptions
    • SaraB
      Dear Geo thank you very much for your reply. I will try to contact the license manager to do that.
      Anyway in the meantime I have managed to make Fluent work by following this step:
      set MPI Types to msmpi , select IP interface: 127.0.0.1
      After doing this once, now Fluent works even with the default MPI and IP interface options.
      Best
      Sara
