TAGGED: 2D, airfoil, flow-separation, fluent, wall-shear-stress
March 25, 2022 at 1:32 pm
dtmaidenmueller
SubscriberFor a class assignment, we have been directed to find the location of flow separation from a FLUENT simulation of flow around an airfoil (uniform free-stream velocity, Re=50k). We were directed to look at the wall shear stress and find the point where it changes sign.
From the simulation results, flow separation appears to occur a little over half-way along the airfoil.
March 25, 2022 at 3:22 pmDrAmine
Ansys EmployeeWall Shear Stress is the magnitude of the wall shear stress component with X,Y and Z (if 3D) the vector components of the wall shear stress. The formal definitions to be found in the Manual.
So the methodology you are using is correct you can even make it more elegant by using X-wise based friction factor (C_f). Whenever that C_f changes the sign (really gets first zero then becomes negative) then separation occurs.
Looking into your geometry it is clear that x direction is not tangential to it: so you can think about some coordinate transformation if you want much more accurate representation.
March 25, 2022 at 3:25 pmRob
Ansys EmployeeIf you look https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/flu_ug_fvdefs.html you'll find the field definitions.
Wall Shear Stress won't switch sign as it's a function of flow speed, which is never negative. I suspect the minimum is what you're after which is the zero velocity point where the flow detaches.
As an aside, the mesh is horrible. You really want more resolution along the wing if you're after the separation position.
March 25, 2022 at 3:34 pmdtmaidenmueller
SubscriberWhere can I find the manual? I can't access Rob's link because it keeps asking me to add an "account number" to my account when I sign in, but I just have the free student version.
March 25, 2022 at 3:35 pmdtmaidenmueller
SubscriberNoted on the x-direction mesh density. Thank you.
March 25, 2022 at 3:42 pmDrAmine
Ansys EmployeeWherever you are in Fluent Hit F1 or click on Help. After a browser opens you can then click on the Link provided by Prof. .
March 25, 2022 at 3:52 pmdtmaidenmueller
SubscriberI can open the workbench help from within workbench (and I can log in fine), but when I try to navigate (from that browser) to Prof Rob's link, it goes back to the page where it wants me to "complete my registration" with an account number.
March 25, 2022 at 3:59 pmDrAmine
Ansys EmployeeForget for now about the workbench: if you just launch Fluent and click on F1 what does it happen?
March 25, 2022 at 4:18 pmdtmaidenmueller
SubscriberWhen I press F1 in Fluent, nothing happens. When I use the menu to access "Online Technical Resources", I end up back at the "complete customer registration" page that wants an account number. The menu option for "User's Guide Contents" opens a page successfully, but I can't seem to find a section for the field definitions. Navigating some links on that page (Home, API Docs) takes me back to the "complete registration" page. I tried entering "Wall Shear Stress" in the search box, and it just spun for about 5 minutes without bringing anything up.
March 25, 2022 at 5:08 pmRob
Ansys EmployeeDon't access "Online....." go to the User Manual as you did. Then put in the link I sent. Ch 37.4 in the Solver section of the User's Guide.
Viewing 9 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
7742
4502
2961
1449
1322
