Fluent UDF: Check if RP_Get_Integer or Get_Input_Parameter exists.
    • K
      I have a UDF that calls a scheme variable (defined by RP_Get_Integer) and an input parameter (using Get_Input_Parameter). I would like to write an "if" statement that performs one task if the variables exist, and another if they don't exist. Is it possible to check whether these variables exist within the UDF?
      There should be, check the documentation: I don't know, and I can't answer other than what's in the documentation. None staff are not under the same restrictions.
