Fluent -udf-density computation of species.
    • sooraj546
      In my UDF code i want to convert my species mass fraction into concentration of the species . So the best way to do it is to multiply with density
      Y_co2=C_YI(c, t, 2); /*Mass fraction */
      Y_co=C_YI(c, t, 5);
      X_co2=Y_co2*C_R(c, t); /*( kg/m3 )*/
      X_co=Y_co*C_R(c, t);
      But  i should multiply with the species density rather than density of the unit cell like i have done here. ............how to get it through UDF?
    • DrAmine
      To get the molar fraction(Yi) you need to calculate the mixture molar mass (Molar_Mix) and then get the mole fraction by Yi=Xi*Molar_Mix/Molar_i.
      For mass concentration ou just need to multiply mass fraction (Xi) by the mixture density. The latter one is accessible though C_R(c,t). So the expression you are using is correct but I guess you are referring to some other definition which I dunno?
      A:
