March 28, 2022 at 2:54 pm
eric1234598765
SubscriberHi,
I'm using Fluent 2020R2 to obtain laminar viscosity and velocity derivative via "C_MU_L(c,t)" and "C_DUDY(c,t)".
The trouble UDF is tested in VOF model with single processor using SST-K-OMEGA, which is going to compute the viscous drag of the "interface" which Fluent can't handle.
Here's UDF:
#include "udf.h"
DEFINE_ON_DEMAND(Viscous_Drag)
Domain *d = Get_Domain(1); /*Get the domain ID*/
face_t f;
cell_t c;
/*Get the thread id of that surface*/
Thread *t = Lookup_Thread(d,6); /* Interface_Fluid_porous1 */;
Thread *t1 = Lookup_Thread(d,7); /* Interface_Fluid_porous2 */;
real force;
real avgf;
int ii;
if (!Data_Valid_P())
return;
force=0.0;
avgf=0.0;
ii=1;
/* Loop over all cell*/
begin_c_loop(c,t)
force = force + C_MU_L(c,t);
end_c_loop(c,t)
Message("Viscous drag is = %8.4f ", force );
After debugging, I found that the Fluent would pop out "Received signal SIGSEGV." error and show the zero value when I using either "C_MU_L(c,t)" or "C_DUDY(c,t)" in the begin_c_loop, and with no problem when using other UDF cell macro such as C_T(c,t), C_K_L(c,t), and so on. However, laminar (molecular) viscosity was checked by xy-plot which is not zero.
Obviously, the problem is the misusing of the C_MU_L(c,t) and C_DUDY(c,t), therefore, I looking forward to any help.
Thanks!
March 28, 2022 at 3:09 pmeric1234598765
SubscriberUpdate:
Same error as stated when the VOF model is off.
March 29, 2022 at 11:13 amRob
Ansys EmployeeCheck if C_MU_L(c,t) needs a phase domain for VOF. I'm guessing, UDFs aren't one of my strong points.
March 30, 2022 at 10:53 americ1234598765
SubscriberHi I've solved the problem by pointing the face thread to the face centroid, which is
Thread *t0 = t->t0; /* Access t0 (Pointer to the adjacent cells thread.) from t (face thread) */
And using adjacent Cell Index in the f_loop , which is:
c0 = F_C0(f,t);
Now, the pointers I set are : t, t0, c0. Using c0 and t0 instead of c and t solve the problem in the loop. So the UDF is like:
DEFINE_ON_DEMAND(Viscous_Drag1)
face_t f; /*Index that identifies a wall face.*/
cell_t c0; /*Cell index that identifies the cell next to the wall.*/
real viscosity;
return;
real NV_VEC (A); /*Area normal vector*/
/* Loop over all surface faces*/
begin_f_loop(f,t)
F_AREA(A,f,t); /*Get the area vector*/
c0 = F_C0(f,t);
viscosity += C_MU_EFF(c0,t0);
end_f_loop(f,t)
Best
Trending discussions- Floating point exception in Fluent
7676
4476
2957
1433
1322
