Fluent UDF – Reading a variable that is generated during the simulation
    • abhaymh
      I have the requirement of changing the input velocity based on the EWF thickness which is a result of the simulation, based on an equation. I wanted to know how I could read the value of the film-thickness into the UDF in order to manipulate it.
      You may be better off using an expression as that can take the film thickness at a position as a Report. There will be an equivalent UDF macro, so check the manual. Expressions are a newer feature in Fluent (based on CFX technology) as a means to avoid needing UDFs for "simple" stuff.
    • abhaymh
      I can use the expression, yes, but here's what I have to do: Use film thickness to calculate a value, then use that value to calculate the flow rate and subsequently the velocity at the flow inlet. For this, I think I will have to use a UDF since the value changes at every iteration. Is it possible to accomplish this using just expressions?
      You can do that with expressions, that's one of the functions they're designed for. Just make sure the expression makes sense for a zero thickness film.
    • abhaymh
      Thank you. While that works to define it, it says invalid expression. As you can see from the image, the expression does give a value in the plot. I'm not sure if I've made a mistake or something.
      EDIT: I've also attached a plot for changing values of film thickness (it makes sense, realistically speaking)
      What is evap_area?
Viewing 5 reply threads
