Fluent UDF: “string_safe.h”: No such file or directory;LINK : fatal error LNK1181: 无法打开输入文件“udf_name
    • WJC
    • RK
      According to the warning, you have probably used a character which is not being recognized. I would suggest to go over the UDF again.
      The UDF will have to be in the same folder as the working directory.
