FLUENT uds units
    • xqzhang
      hello, everyone. I am building a pem fuel cells model, and I have a question. When I write uds, if I use mol*m-3*s-1 as the unit, the calculation is normal, but when I change teh unit to kmol*m-3*s-1, the calculation result is wrong. If I want to use kmol*m-3*s-1 as the unit of source term of UDS, do I need to change the default unit or others in FLUENT? Besides, does change the unit of source term speed up the convergence?
      Changing the units shouldn't effect convergence as the actual numbers used in the solver are converted to SI.
    • xqzhang
      Thank you very much for your answer.
