FLUENT unreasonable gas holdup
    • jiangtao.lu
      I am using Euler-Euler model to simulate stirred tank reactors.
      At low viscosities (~0.02 [Pa m]), gas holdup is about 0.15, which is normal.
      At increased viscosities (~0.08 [Pa m]), with other things unchanged, gas holdup increases to ~0.5, which is quite unreasonable.
      Anyone has a clue? Thanks.
      Forum Moderator
      What's the bubble diameter?
    • jiangtao.lu
      Thank you Rob for replying. The bubble diameter is 5.5 mm. I expected some increase, but not that large
      Forum Moderator
      Can you post some plots? Are you modelling a free surface or using degassing?
    • jiangtao.lu
      I used pressure-outlet. Due to confidentiality, I blacked some parts in the figure, but I guess enough to tell the difference
      Forum Moderator
      You've lost the free surface too. How does the convergence look as the system looks like it's trying to foam.
    • jiangtao.lu
      yes, I have the same suspicion as you: foaming. The convergence has no problem, energy dissipation is oscillating as expected.
      Forum Moderator
      Hmm. Can you run a couple of time steps with no gas injection and then switch on the gas?
    • jiangtao.lu
      It is a transient simulation. At beginning it is ok, clear free surface, reasonable gas holdup, just like the left panel. Gradually, it develops into the right panel.
    • jiangtao.lu
      Do you know if FLUENT tested increased viscosities? to which value?
      Forum Moderator
      We did, but not sure on the values - we do run with oil as the carrier phase for pipe flows.
    • jiangtao.lu
      well, horizontal flow will behave differently from my case for free surface, mixture expansion, etc
Viewing 11 reply threads
