August 9, 2019 at 1:36 pm
wolterj
SubscriberHey,
following Problem:
I try to simulate flow throught a nozzel.
Physics:
Transient, Pressurebased
VOF-simulations 2 phases(Water-liquid/Air) Implicit body force, level set, interfacial anti-diffusion. Viscous model is SAS.
With Sufcae Tension and Wall adhesion
Boundryconditons is a profil from Simulations of the inlet-pipe(50mm long with a diameter of 3mm)
Solving:
PISO
SC: 2
NC: 1
N/C coupling
Gradient
Least Cell....
Pressure:
PRESTO!
Momentum:
Bounded central Differencing
Volume-Fraction:
Geo-Reconstruct
Turbulence Kinetic energy:
Second Order
Rest: first order
Controls:
Pressure: 0.8
Desity: 1
Body Forces: 1
Momentum: 0.7
Turbulence Kinetic Energy: 0.8
Specific Dissipation rate: 0.8
Turbulent Viscousity 1
Level set Funktion 0.3
This setup were copied from an earlier project. in which somebody simulatet sth similar (simpler geometry of the nozzel)
Initialization Hybrid:
1 1.000000e+00
2 1.483658e-03
3 2.464239e-04
4 7.808120e-05
5 1.954829e-05
6 2.758029e-05
7 7.300978e-06
8 1.637179e-05
9 3.304232e-06
10 5.462358e-06
11 1.297115e-06
12 2.780550e-06
13 5.708590e-07
14 1.221940e-06
15 2.387166e-07
Time step size: 5e-5s
im using ANSYS 19.1
If any more data is needed dont mind to ask.
Thanks for ur help
August 9, 2019 at 1:39 pm
wolterj
SubscriberMesh:
Check:
Domain Extents:
x-coordinate: min (m) = -2.298173e-02, max (m) = 7.017803e-03
y-coordinate: min (m) = -2.199953e-02, max (m) = 8.000000e-03
z-coordinate: min (m) = -1.910000e-01, max (m) = -1.510000e-01
Volume statistics:
minimum volume (m3): 6.296011e-14
maximum volume (m3): 8.751962e-11
total volume (m3): 2.268875e-05
Face area statistics:
minimum face area (m2): 1.152058e-09
maximum face area (m2): 4.271876e-07
wolterj
SubscriberMesh:
Quality:
Minimum Orthogonal Quality = 7.22601e-02 cell 351028 on zone 2 (ID: 2859648 on partition: 7) at location (-5.55571e-03 -7.51119e-03 -1.56400e-01)
(To improve Orthogonal quality , use "Inverse Orthogonal Quality" in Fluent Meshing,
where Inverse Orthogonal Quality = 1 - Orthogonal Quality)
Maximum Aspect Ratio = 4.45425e+01 cell 354648 on zone 2 (ID: 2850200 on partition: 0) at location (-9.28973e-03 -8.64463e-03 -1.56400e-01)
August 9, 2019 at 2:02 pm
DrAmine
Ansys EmployeeCheck if poor quality is related to some few cells but even some few cells with poor metrics might cause issues. Under solver expert (TUI) enable saving residuals and post-process them to see where they accumulate.
August 18, 2019 at 6:02 pm
wolterj
Subscribergot a better quality but still problems but not as bad as before. Its still converging to slow
Minimum Orthogonal Quality = 2.07948e-01 cell 167471 on zone 2 (ID: 5768309 on partition: 14) at location (-9.47030e-03 -7.19996e-03 -1.59992e-01)
Maximum Aspect Ratio = 1.60527e+01 cell 26041 on zone 2 (ID: 5959628 on partition: 14) at location (-6.47500e-03 -8.72246e-03 -1.59122e-01)
August 19, 2019 at 5:02 am
DrAmine
Ansys EmployeeWhat kind of mesh do you have. CLSVOF and surface tension better with structured uniform grid.
2706
2142
1355
1144
462
