Fluent Volume integral question
    • lguessous
      Hello. I would like to define a region in a cylinder that is part of my Fluent domain and perform a volume weighted integral of a quantity (say pressure) in that region. How do I go about defining a volume region to be used for the integration. I can create a surface or isosurface, but can't seem to be able to create a fluid volume zone that I can then use for the integration. We are using Fluent version 2019 and 2020. Thanks.
    • ai0013
      I am not completely sure if the mark registers option will allow you to do this. My feeling is that you'll need to define a cellZone since your mesh generation process. This way Fluent will recognize it as another selectable fluid region, so you can perform the volume weighted integral
