November 30, 2022 at 4:52 pm
mechE
SubscriberHello,
I am trying to start Fluent 2022 R2 in gpgpu mode (by using the native GPU solver option on the Fluent start screen). However, I see the following error and Fluent stops responding as soon as it starts -
GPU Solver (Beta) enabled
999999 (C:\ADOagent\_work\2\daily_dev22.2\ansys_inc\v222\fluent\fluent\multiport\src\mpsystem.c@1236): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 7336 RUNNING AT ANSYS-CL-36
= EXIT STATUS: -1073740791 (c0000409)
I have the following GPU on my machine -
CUDA visible GPUs on ANSYS-CL-36
CUDA runtime version 6000
Driver version 9020
Number of GPUs 1
0. Quadro K620
3 SMs
1.124 GHz
2.14748 GBytes
Any ideas on why this doesn't work? Would appreciate any help on this!
December 1, 2022 at 11:44 am
Ansys EmployeeIt is a beta feature.... Check the gpu is on the supported list, and that you are attached to the Uni licence server.
December 1, 2022 at 4:00 pm
mechE
SubscriberThank you for the response Rob. Based on the Fluent 2022 R2 release notes my gpu should be supported -
"Fluent supports NVIDIA's CUDA-enabled workstation, data center and server cards."
Also, I am trying this on campus, so I am connected to the license server for sure. I can start and run Fluent in regular parallel CPU mode without any trouble.
Any other ideas on things to try?
December 2, 2022 at 10:57 am
Ansys EmployeeThere's the usual "update the drivers" and also, run "nvidia-smi" from the DOS window. I assume you're not trying to autoload a case, and have 3ddp selected?
2524
2066
1279
1096
459
