Fluent with RSM , gz compression
    • zibul
      Is it possible to turn off gz compression in fluent and then register job in RSM? If you have a very large job and slow one core in ypur CPU loading when cas and dat file is wrting is terrbily!!!!!! n
    • Karthik R
      Administrator
      I'm moving this post to the Fluids category for better alignment. Unfortunately, there is no way to turn off compression when using Fluent with WB. nYou could however accelerate the write times by using SSD. Just wanted to throw this piece of information out there. I hope this helps. nThanks.nKarthikn
