October 5, 2017 at 2:44 pm
veersarao
SubscriberHi all,
just started using fluent 18.2 academic version.
system configuration:- window 10; Intel Xeon; 16 GB ram; Nvidia Quadro M1000M
After launching fluent all I can see is a black graphic window no matter what I choose or insert mesh.
I already tried changing the colour scheme from workbench to classic.
Please find the attached screenshot.
hope you would be able to assist me.
Thanks,
Veer
October 5, 2017 at 2:55 pm
Vishal Ganore
Ansys EmployeeLooks like colour scheme should be changed from Classic to Workbench.
October 5, 2017 at 4:14 pm
October 5, 2017 at 5:42 pm
October 5, 2017 at 6:45 pm
veersarao
SubscriberThanks vganore for getting back to me.
Still black screen. However, I Installed older version 17.2 and Fluent in this version working perfectly fine.
October 24, 2017 at 2:59 pm
orndui
SubscriberI have the same problem.
I'm using Ansys 18.2, have tried both with and without the Workbench Color Scheme to no avail.
I'm running Windows 10 on a Dell XPS 15 9560, with an Intel HD 630 graphics card.
Is there a solution to this, other than downgrading to version 17?
October 24, 2017 at 7:06 pm
Vishal Ganore
Ansys EmployeeWe don't support Intel graphics card. Could you please try to pop out the graphics window? It may or may not work.
November 3, 2017 at 4:52 pm
Mmikal
SubscriberHi, so I had the same problem regarding the black screen when you start Fluent. It took me a while, but I believe that I found a solution. Most probably you have two video cards: intel (integrated) and NVidia as dedicated. Apparently, fluent does not use NVidia as default video card. If I press second mouse button on fluent>Run with graphics processor>High Performance NVidia , it works fine. I have manually changed the default graphics card and for the moment everything looks fine.
November 4, 2017 at 1:49 pm
orndui
Yep, that solved it for me also. Annoyingly I can't seem to make this the default option in the NVidia Control Panel. Guess I'd have to talk to NVidia about that.
November 15, 2017 at 7:52 pm
OliverW
SubscriberHey,
I have the same issue with that black screen but in ANSYS Workbench Mechanical v18.
Does anyone know where I find the .exe (under the ANSYS directory tree) to launch it via my NVidia Graphics cards?
November 17, 2017 at 7:01 am
Vishal Ganore
Ansys EmployeeYou could set NVidia as your default graphics card then try opening Workbench.
February 13, 2018 at 5:02 pm
jsokol
SubscriberHello,
I have the same issue with ANSYS 18.2/Fluent (entire graphics screen is black). Have tried changing the Workbench Color Scheme without success. Please help! Is there any way to use Fluent without a dedicated graphics card??
Computer specs:
Lenovo Thinkpad X1 Yoga 2nd Ed
Windows 10 Pro
Intel Core i7-7600 CPU @ 2.80 GHz
Intel HD Graphics 620
February 14, 2018 at 4:01 pm
AndiMb93
SubscriberHi,
we had the same problem with the black screen in Fluent since Ansys 18.2 on Intel HD Graphics. We solved it by application specific setting of the Intel graphics driver.
Open the Intel Graphics Driver Control panel -> goto 3D -> add the Fluent executable as application and make sure, that the "Multi-Sampling Anti-Aliasing" is disabled.
The Fluent executable is located in the folder C:Program FilesANSYS Incv190fluentfluent19.0.0cortexwin64 an case of Ansys 19.0 and it is called cx1900.exe. (Change 19 and the first 0 to 18 and 2 in case of Ansys 18.2)
In our case Fluent is now working including 3D Graphics.
Regards
Andreas -
April 24, 2018 at 8:57 am
Naiara
SubscriberHello,
I have Ansys 19.0 installed and I did what you say above graphic window is steel black, any idea of what can I do?
My computer have Intel HD Graphics 520.
Thank you,
Naiara
April 24, 2018 at 1:25 pm
April 25, 2018 at 8:15 am
Naiara
SubscriberHi Rahul,
Now it works!
Thank you!
Naiara
September 6, 2018 at 12:47 pm
September 11, 2018 at 3:53 pm
tsiriaks
Ansys EmployeeHi asma,
Could you create a new thread ?
You can mention on there that you have tried the resolution in this thread with no success.
Also, I'm quite confused the real issue you are having.
Do you have issue with Fluent black screen or that low memory message ?
Thank you,
Win
November 13, 2018 at 6:25 pm
Josh
SubscriberHey,
I have the same problem with the black screen in fluent (ANSYS Workbench: Academic Student Release 19.2)
This is what I tried:
- Changing the color scheme was not solving the problem
- I have no NVIDIA graphic card, only a Intel Iris Plus Graphics 640 (Surface pro)
- I don´t have “Intel Graphics Driver Control panel“, so I can´t disable the "Multi-Sample Anti-Aliasing".
Is there someone who can help me?
Thank you,
Josh -
November 14, 2018 at 1:47 am
tsiriaks
Ansys EmployeeHi Josh,
As mentioned above, this thread has been solved, please create a new thread for your issue. You can still refer to this thread by adding the link
https://forum.ansys.com/forums/topic/fluent-s-black-graphic-window/
in your new thread.
In the meantime, you can try updating your integrated Intel graphics driver and see if you get any luck.
Thanks,
Win
December 12, 2018 at 3:45 am
samuelford
SubscriberI have the same problem. The window of fluent is still back even after I changed the color scheme and reinstalled the software.
December 12, 2018 at 5:03 pm
tsiriaks
Ansys EmployeeAs mentioned above, this thread has been solved, please create a new thread for your issue.
Thanks,
Win
February 5, 2021 at 6:47 am
rashid
SubscriberHi hello sirniam facing the same issue with fluent(results) not fluent(solution) can you let me know how to install an older version ?n -
December 3, 2022 at 8:53 pm
- Workbench error
- Workbench not opening
- License Error
2656
2116
1337
1118
461
