Fluent’s question about wind direction
    • xianxian
      Hello everyone,
      I want to simulate the ventilation problem of a tall&large building. I am wondering why the wind direction at the bottom of the wind farm is downwards?
      I want to simulate the temperature field in the room, but the current result is that the room temperature is still low with floor radiation. I think it may be a problem with the wind. Please give me some suggestions, thank you.
      Can you show an image of the geometry (just show walls)?
    • xianxian
      Thank you very much for your help.
      The images of the geometry are as follows:
      1) This image shows the temperature of the walls(include windows)
      2) This image shows the walls except windows:
      In order to simulate the radiant floor, I placed a hot plate on the floor of the building (h=0.5m, energy sources: 140W/m3). I don't know if it is a hot plate problem?
      Did you apply the heat to the wall or to a volume?
    • xianxian
      Yes,i apply heat flux on the floor. Actually, sometimes the wind direction of my case is right, but sometimes is not. Is there any problem with the mesh?
Viewing 4 reply threads
