Fluent::Unable to save ‘Reference Values’ Compute from settings.
    • arunhsc
      I am trying to set the 'Reference Values' to compute the velocity from the inlet zone. When I select it and run my calculations it works for the current set up.
      If I close Fluent and open it back again this setting goes back to the default of 'Blank'.
      Any idea how to save this settings so that I can change my velocity as a Design Point parameter from Workbench and use the right values of the 'Reference Values' of inlet velocity for the corresponding design point.
    • DrAmine
      Are you opening from setup cell? If not then please do that and save settings.
    • arunhsc
      Thank you for your reply abenhadj
      I am not sure what you mean. But I am accessing the settings as shown.
      The issue is not that my zones are missing, its just that the option i select (in this case my inlet) is not retained for further sessions.
    • DrAmine
      In the workbench you need to open Fluent from setup cell. If still am issue let us know
    • DrAmine
    • arunhsc
      I am opening Fluent from workbench thus:
      Once I have made the 'Reference Value > Compute from' changes I save the project as show:
      But when I open the set up again that particular setting is back to default.
      The interesting thing is the rest of the changes I make are retained when I follow the above process. This is also true for 'Reference Value > Reference Zone' option at the bottom of the 'Reference Value' page.
    • DrAmine
      Workaround will by using automatic case modification or startup scheme.
      Which version are u using,?
    • arunhsc
      I am using Ansys 2019 R3: Academic.
    • DrAmine
      Then stick to the workaround suggested first.
    • arunhsc
      Amine, Thank you very much for your time and help.
      I am a very basic user of Fluent/Workbench. However I shall look up for those topics.
      The other question is why you need the reference values: they don't do anything in the solver and are only used for some post processing.
    • arunhsc
      The idea is to be able to automate the calculation of drag coefficient for a set of design velocities as shown:
      I could have used the drag force to calculate the coefficients, but I was trying to automate everything so that I can run the same experiment on all my geometries overnight.
    • DrAmine
      Better to write a user defined report definition with output parameter or use Report definition expression option
    • lordofthethings
      Hi Arun,nDid you find a workaround for this? This is a crucial point when parameterising the simulation. Even in my case the reference values are going to blank because of which the post processed values are not correct (in my case, the Nusselt number and heat transfer coefficient.)nCould you please share with me the workaround if possible?nRegards,nParitoshn
    • Karthik R
      Administrator
      Hello lordofthethings, We are responding to you here.
      Karthik
Viewing 14 reply threads
