FLUENT:What is the default FPS speed when the slider is set to FAST; in Solution Animation Playback?
    • ai0013
      Hello
      in Fluent: I would like to know what is the default fps speed when the slider is set to FAST in Solution Animation Playback?
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      i do not think that it is specifically mentioned in help manual. but please check it once.
      you can always write mpeg file from fluent and watch outside fluent.
      Keyur
