December 5, 2020 at 6:05 pm
mario.peres
SubscriberHello, my name is Mario and I am new here. I am also new at using Ansys products by the way. Anyhow, I want to perform a risk assessment for COVID transmission within city buses here in Brazil. I have seen may tutorials and I know how I have to setup my simulation but I cannot do it using an autcad image of a bus that I downloaded from internet. Is there any special needs in the image for this kind of analysis? Could you please let me know where I can find this type of image for this type of analysis? Thanks a lot in advance.
Best wishes,
Mario Peres
December 7, 2020 at 4:06 am
Charudatta Bandgar
Forum ModeratorHello MarioPeres , You will not able to do a simulation on an image file, for that you will need a 3D CAD geometry file (usual formats .scdoc/.step/.part), or you can make it on your own in SpaceClaim, please refer to the SpaceClaim tutorials. Once you have a 3D CAD model, you can create an internal fluid flow study, but the details of which will depend on what you want to achieve and based on your understanding of the problem statement. You can find the fluid flow studies in Discovery here to understand better. Please let me know which tool you are/will be using so that it will be easier to assist. Regards.
- The topic ‘fluid analysis of Bus interior’ is closed to new replies.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1688
1474
