November 18, 2019 at 4:32 pm
jsf4801
SubscriberHello All,
I am designing a canoe currently and would like to test the drag force on the canoe. I have imported my CAD geometry but I am struggling to determine the dimensions of my fluid domain for the canoe. The canoe is 19 ft long, 2.5 feet at its widest point, and has a depth of 16 inches. Also is there a certain way to determine my free surface as well?
I am very new to CFD and any help at all would be appreciated.
Thanks
November 18, 2019 at 5:21 pm
Ansys EmployeeFree surface can be modelled using VOF in Fluent, but you'll need to decide where the canoe sits (depth) unless you want to get even more involved and use the 6DOF solver.
In terms of the domain size, have a look for wind tunnel and/or water flume rules and apply those. You may also want to consider symmetry to keep the cell count down.
November 18, 2019 at 6:20 pm
November 19, 2019 at 11:25 am
Ansys EmployeeBest way to check is to plot velocity & pressure contours. If you can see a higher pressure on the sides or artificially accelerated flow the domain is probably too small. You may need to adjust the scale depending on the range.
November 25, 2019 at 11:05 am
saifali
SubscriberHello Can you share the file
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5290
3311
2471
