Discovery Import
Discovery Import
Fluid error, SystemError
    • info
      Hi Brian,
      I got the enclosed error message after initiating the Physics solver.
      https://drive.google.com/open?id=1Io8LfAyM1CsEeW-Nw07uwhNU4WNtGnlL
      Please help me to fix this, or at least give me some hints.
      Thank you in advance.
      Csaba
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Gaurav Sharma
      Hi steelxpert
      To begin with, a couple of things can be worth a try:
      1. At times, "program fail to initialize" errors can be tackled by updating the graphics driver. It is recommended to use manufacturer's website to get the latest driver and not rely on window's update.
      2. There is also a mesh related warning in your setup, you may like to fix it and see if this helps.
      If this doesn't work, I would like to have a look at the setup. Please let me know if I need to share the securetransfer link to transfer the model.
      Thanks & Regards,
      Gaurav
