AIM Tutorials
AIM Tutorials
Fluid Flow – Flow in a S-Duct
    • svecchi
      In this tutorial, the velocity vectors and pressure profile will be simulated in an S-duct. The flow volume has been provided. Flow will enter the large volume upstream of the S-duct and exit from the end protruding from the large volume. The pressure at the inlet will be 88744 [Pa] and the outlet will be supersonic. See the attached file for the tutorial.
    • lazarev.t.v
      Hi.
      Im trying to perform S-duct simulation with your tutorial. But unfortunately geometry attached in post  is not the one mentioned in tutorial (content of file is on attached picture ). Could you please share correct file.
      My mail - lazarev.t.v@gmail.com
      A Lot of Thanks
