August 17, 2017 at 6:14 pm
svecchi
Ansys EmployeeThe Ahmed Body is a standard wind tunnel model used to represent ground vehicles. It was first defined and characterized by S.R. Ahmed in 1984 and has been used since to study the effects of drag and aspect ratio. In this tutorial, we will subject an Ahmed body to air at 40 m/s in order to find the velocity vectors, pressures on the body, and streamlines around the body. See the attached file for the tutorial.
- I’m a starter
- YouTube tutorial files
- Fluid Flow – Lid Driven Cavity
- Thermal – Heat Conduction in a Cylinder
- Fluid Flow – Turbulent Flow Over a Backward Facing Step
- Fluid Flow – Taylor-Couette Flow between Rotating Cylinders
- The project files directory doesn’t exist
- Magnetics-Permanent Magnetic Circuit with Air Gap
- Process ‘3dedy’ terminated abnormally. It may have run out of memory or could have been killed by..
- vibration
2656
2120
1347
1118
461
