August 17, 2017 at 6:16 pm
svecchi
Ansys EmployeeIn this tutorial, the velocity vectors, pressure profile and streamlines will be simulated in a 180 degree U-bend square duct. The material passing through the duct will be air with an intake velocity will be 12 m/s which is comparable to the speed of air in an office HVAC system. See the attached file for the tutorial.
- I’m a starter
- YouTube tutorial files
- Fluid Flow – Lid Driven Cavity
- Thermal – Heat Conduction in a Cylinder
- Fluid Flow – Turbulent Flow Over a Backward Facing Step
- Fluid Flow – Taylor-Couette Flow between Rotating Cylinders
- Magnetics-Permanent Magnetic Circuit with Air Gap
- The project files directory doesn’t exist
- Process ‘3dedy’ terminated abnormally. It may have run out of memory or could have been killed by..
- vibration
2616
2098
1323
1108
461
