January 27, 2021 at 9:37 pm
desouzadacosta
SubscriberHello,
I want to duplicate the solution of column A into column B without using refresh or update. If I use refresh or update the solver runs the case from the beginning again.
How can this be done ?
January 28, 2021 at 11:38 amRob
Ansys EmployeeDo you just want to start a transient solution from the steady data? nFebruary 3, 2021 at 2:10 pmdesouzadacosta
SubscriberHi Rob,nSorry for the delay.nI want the duplicate column B (the unsteady one) with the steady (column A) solution already available.nIf I use refresh in Solution of column B, it is going to start all the Solution A again.nThanks.nFebruary 3, 2021 at 4:39 pmRob
Ansys EmployeeNot sure I follow. If you duplicate A you should get all of the results too. Alternatively you can use a Fluent workflow (no geometry or mesh) and copy the case & data from A into it to then run in transient. We tend not to use Workbench as much now as it's often easier to manually copy/move files and save with descriptive names. nFebruary 8, 2021 at 7:21 pmdesouzadacosta
SubscriberThanks. I going to try that.nViewing 4 reply threads- You must be logged in to reply to this topic.
5242
3299
2469
